Do I Need An Intercooler
#41
Also like this, I have talked to a couple of guy's that are running around 450rwhp with an intercooled supercharger ( all stock internal's). Wouldn't that be about the same as running 350 rwhp without the intercooler, or am I just crazy
![Screwy](https://themustangsource.com/forums/images/smilies/screwy.gif)
#42
I have the money for the intercooler
, I just don't think I want 400 rwhp. I would be really happy with 350rwhp, that's my whole point on not wanting the intercooler because I don't think I would need it with 350 at the wheels. If I want more power later I will get the intercooler................. can you smell what i'm cookin?![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
![Icon Mrgreen](https://themustangsource.com/forums/images/smilies/icon_mrgreen.gif)
If you only want 350 rwhp, this is possible while staying N/A. You can get a set of heads and cams, which have become readily available in the recent months, a set of LT's, UDP's, and if that doesn't get you there...F.A.S.T. is coming out with their Intake Manifold pretty soon, and with the addition to that, you should easily make 350 rwhp and it will be more reliable than a 5psi non-intercooled S/C.
Just some things to consider.
Also, once you get a taste of 400+ rwhp, you'll want more. Trust me!
#43
Obviously 350 rwhp is not the same as 450 rwhp, and while the percentage difference is not huge, and the 0-60 difference is not huge, the difference in the way the car "feels" is massive. Think; spinning tires at will, slamming your head into the headrest, etc... I've also got to disagree with S197 GT, getting a true 350 rwhp naturally aspirated is NOT easier (or cheaper) or more reliable than slapping on a low output Vortech. I know because I had one of the top mustang shops do the following;
o JBA Long tube headers
o JBA High flow cats
o FRPP "quiet" mufflers
o Underdrive pulley system
o Cold air kit with "Trueflow" inlet pipe
o FRPP 3.73 Ring & Pinion
o Steeda Charge motion control delete kit
o SHM ported and polished stage 1.5 heads
o FRPP Spark plugs M-12405-3V0 (one heat range colder than stock)
And only achieved 321 rwhp (note however that it's a 91 octane tune and that rwhp is dead accurate, I've reproduced it at 3 different places). This process cost about twice as much as a Vortech, even more than that if you consider that I could have installed the vortech myself in an afternoon... If I had gone with strong valve springs, big cams and ramped the RPM up to 7000+ I could have hit 350. But that would have cost even more and reliability would be worse than the non intercooled vortech.
My main point is; The low output kit is NOT just a non-intercooled big vortech kit. It's a smaller low output compressor giving less air and less heat. This means it's got similar reliability than the full intercooled kit, and it's NOT easily upgradable to the full kit. If you think you'll want more power in the future keep saving your pennies and buy a full kit later on.
#45
Actually, it IS an easily upgradable kit.. I did it!..The compressor unit is exactly the same, injectors are the same, all components are the same.. Only additional components you get are the cooler, heat exchanger, different predator with an adjusted tune etc...Its NO BIG DEAL to upgrade later if you want.
#47
What I meant by this was wouldn't the risk of detonation and the temp's be the same with a 350 rwhp non intercooled supercharger and a 450 rwhp intercooled supercharger. I know the power wouldn't be the same.
#48
#49
I think you have a pretty valid point there. The point I was trying to make in my post earlier was having the extra padding of safety, which you can really do at 350 rwhp. Having a car you worry about is not fun. If you go intercooled and start jacking the boost up, you are in the same boat again, just a faster one. ![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
#50
It looks like I was wrong about the Vortech. I apologize about the possible miss-information, lord knows there's already enough noise on these boards... But I'm definitly not wrong about the Paxton, it says so right on their website, that's to say that the low output and the high output kits use two different compressor units. So while you can put an interooler on the low output that won't make it equivalent to the high output.
Personally I went for the high output, If you use their supplied pulley and don't try to push more power out of it, it should be reliable. Has ANYONE heard of ANY Vortech/Paxton S/C'd engines blowing at base pressure in a Mustang??
#51
If you want to look at Paxton, call Brenspeed as they sell a LOT of Paxton kits. They're mainly all 'cooled, but I'm sure they could work it for you without if that's what you want.
#53
Hey Tom, I am waiting for a call back from a local shop because I might be getting hooked up on a paxton 2200. If not i'll be ordering the paxton 2200 from brenspeed![Icon Mrgreen](https://themustangsource.com/forums/images/smilies/icon_mrgreen.gif)
Trust me i'll be letting everybdy know when it goes down
#55
When I got my fully polished Vortech,I had the choice of the Paxton or the Vortech,since they are both Vortech products,my sponsor gave the choice ,the Paxton is a larger unit and the intercooler is a little different makes more power in the long run ,but I liked the looks of the Vortech better plus I've been told the Vortech is more reliable. Besides I can always put a bigger compressor on in the future if I want even more boost.This couldn't have been possible without my great sponsors Vortech Engineering, Auto Meter Products and Spectreperformance.
#57
I'm surprised no one hasn't pointed this out, but this isn't a reliability issue at all. Vortech has already taken the technical concerns into account and have reduced the output of the non-intercooled kit to equalize the reliability of the intercooled/non-intercooled kits. The non-intercooled kit has a smaller supercharger that pumps out less psi and less heat. So if you're okay with the lesser power output and you're not planning future upgrades go with the lighter, cheaper, simpler non-intercooled S-Trim kit. Simple.
#58
When I got my fully polished Vortech,I had the choice of the Paxton or the Vortech,since they are both Vortech products,my sponsor gave the choice ,the Paxton is a larger unit and the intercooler is a little different makes more power in the long run ,but I liked the looks of the Vortech better plus I've been told the Vortech is more reliable. Besides I can always put a bigger compressor on in the future if I want even more boost.This couldn't have been possible without my great sponsors Vortech Engineering, Auto Meter Products and Spectreperformance. ![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
Is the regular V2 much louder than the SQ version?
#59
They are Spectreperformance. Spectreperformance sent me all different sizes of the steel braided hoses material in large rolls and I cut it to the size I needed. You can buy it in rolls or individual lengths. I was lucky , Spectreperformance is one of my sponsors.
redrock35
05-09 Exterior Modifications
7/31/16 08:50 PM
