Do I need an alignment after installing LCA's?
Old Sep 11, 2006 | 09:00 AM
Chaotic Bliss's Avatar
I am about to do this and was wondering if I would need an alignment after installing my BMR LCA's?
THanks
Old Sep 12, 2006 | 08:27 AM
harleybill's Avatar
Nope. All you did is replace the stock ones and you probably used the same length/alignment for the new Lca's that you had on the old ones so why would you think you needed one? You simply improved the product but didn't really change any angles and such.
You really have to lower the front (springs) before you need a wheel alignment. You can add springs and Lca's and a panhard bar and other support to the rear and not need a wheel alignment. You might need an adjustable panhard bar if you have wide tires and one sticks out of the wheelwell more than the other side but that's about it.
Old Sep 12, 2006 | 07:13 PM
traffic142's Avatar
No you don't....good question, but you will be fine.
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
