DIY Line Lock Question
Old Jul 8, 2006 | 06:40 PM
nonsensez9's Avatar
The guy at the auto parts store gave me some teflon tape to use on the tapered pipe fittings that screw into the solenoids. Should I use the tape on the flare nuts, too?
Old Jul 8, 2006 | 07:56 PM
mikem's Avatar
Tape is useless if you dont do the flares correctly.NO TAPE.Brake fluid would eat it anyways.
Old Jul 9, 2006 | 05:06 AM
nonsensez9's Avatar
good point. the flare nut itself doesn't do anything but press the double flare into the fitting. i was kinda wondering if it was a bit like lock-tite
Old Jul 10, 2006 | 05:26 AM
dustindu4's Avatar
9 is not my lucky number.
Mike is right, the Teflon tape dissolves as soon as brake fluid touches it
Old Jul 10, 2006 | 04:00 PM
nonsensez9's Avatar
If brake fluid ever reaches the threads on the flare nuts I have bigger problems. What is the purpose of teflon tape on the tapered pipe fittings if it will dissolve immediately? What is the purpose of teflon tape, period?
Old Jul 11, 2006 | 05:03 AM
dustindu4's Avatar
Teflon tape is a good sealant for stuff like water and air, not corrosive fluids.
Old Jul 12, 2006 | 03:02 PM
Webba's Avatar
Not entirely true. Virgin Teflon is very chemical resistant. Tape may be a blend if it is dissolving. See below.
Virgin PTFE
Polytetrafluoroethylene (PTFE) is a high molecular weight polymer, one of the most versatile plastic materials known and useful for a large range of products for applications excluded to other materials. The most outstanding characteristics are:
  • high heat resistance
  • high resistance to chemical agents and solvents
  • high anti adhesiveness
  • high dielectric properties
  • low friction coefficient
  • non-toxicity.
PTFE is generally considered a thermoplastic polymer; at 327°C it maintains a very high viscosity, thus requiring particular transformation techniques for manufacturing of finished and semi-finished goods. PTFE can be employed at any temperature from -200°C to +260°C.
Back to topic
Old Jul 12, 2006 | 03:34 PM
FoMoCo's Avatar
I used Teflon tape to install the pipe fittings into the linelock, no leaks at all .
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
DEPUTY62
Sep 12, 2015 11:12 AM
Sep 8, 2015 10:45 AM
