Did I misplace a shifter bolt??
Old May 18, 2006 | 03:33 PM
sis27's Avatar
After everything thats been going on with the B&M shifter I'm going back to the stock shifter. However, when I opened the box where I kept the shifter and OEM bolts and I only found the shifter, 1 hex screw, and 1 clip.
I can't remember if I reused the bolts or if I lost them. If I did misplace the bolts am I screwed?
Simon
Old May 19, 2006 | 01:59 PM
BuzzyStang05's Avatar
There was a similar post a few weeks ago before the upgrade. Someone lost the clip. There was a picture posted also, but it no longer shows. I don't know about a hex screw, but you should have a clip and two 10mm hex nuts.
Here's the post
http://forums.bradbarnett.net/showth...highlight=clip
Old May 19, 2006 | 02:05 PM
MaverickMLFD371's Avatar
yea i made that post, forget about finding those clips, they only come on the assembly of the stock shifter. they arent needed. And yes, you reused the 2 hex nuts that bolted the shifter bracket to the studs. However for the tranny shifter linkage to the shifter nut, B&M supplied their own. If you need that hex nut, talk to KC, he will give you the part# and go to your dealer and ordet the part, should be like $1 for the nut.
Old May 20, 2006 | 06:17 PM
sis27's Avatar
Thanx for the tip Maverick. I'll PM KC now.
Simon
Old May 23, 2006 | 06:43 AM
any luck sis?
Old May 23, 2006 | 07:20 AM
sis27's Avatar
Thanx to you and KC I was able to get the part# for the front support bolt. Now I just need to go to Lowes and get 2 10mm nuts and 1 13mm nut for the rest of the shifter.
I thought I lost more bolts but when I looked at the instructions from another source I realized it was just one lost bolt and 2 nuts. LOL, that really doesn't sound right.
Old May 23, 2006 | 11:39 AM
you can get those 10MM nuts too from KC with the part number as well, but hey man, glad i could help!
Jul 8, 2016 08:53 AM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
