Did anyone use the "MAF mount" on the C&L kit?
Old Oct 25, 2006 | 02:02 PM
eci's Avatar
eci
talk about a cheesy mount...
It's insane that you just jam it in the valve cover buttresses and tighten it down. Couldn't they have made a better mount that fit flush on top of the valve cover hole?
Old Oct 25, 2006 | 02:12 PM
mrkabc's Avatar
I didn't use the mount.
It appeared to dig into my upper radiator hose - I thought that vibrations over time between the sharp point of the mount would eventually wear a hole into the hose.
Also, I don't like taking one of my valve cover bolts off - any time that happens it's an oil leak!!
Old Oct 25, 2006 | 08:09 PM
Keystone's Avatar
If I remember right I used a dremel to notch the bracket and slid it under the nut that way. All I know is it's been on for over a year now and no problems.
Old Oct 25, 2006 | 11:11 PM
eci's Avatar
eci
Can you post a pic of yours? Thanks if you can...
Old Oct 25, 2006 | 11:42 PM
Eleanor Dreaming's Avatar
I didn't use it and mine has been in for approx. 5000 miles. Brenspeed said they don't use it either.
Old Oct 25, 2006 | 11:46 PM
eci's Avatar
eci
I just went out in the garage and removed it. It seems the 07 valve covers have ribs that the 05/06 don't. It made mine just not fit right.
Old Oct 26, 2006 | 04:33 PM
34124231user's Avatar
I did the same thing on mine! It works great. I think it added maybe 0.003 hp
Old Oct 26, 2006 | 05:07 PM
GIG4FUN's Avatar
used mine. fit fine.
Old Oct 26, 2006 | 07:30 PM
Thomas S's Avatar
I used mine but the supplied bolt wouldn't tighten all the way. Like it was too long. I ended up using a couple of extra washers to get it tight.
Old Oct 26, 2006 | 10:41 PM
RPM's Avatar
RPM
I used the brace also. No problems
Old Oct 27, 2006 | 08:21 AM
LeeB99's Avatar
The bracket is not supposed to be "jammed" into the gap in the valve cover. It is installed by placing it on top of the hole and then running the supplied bolt and washer though the bracket and valve cover. We have seen people try to use the rubber grommet that was in the stock bolt, and it was not intended to be used that way. I never thought that anyone would be led to believe that you are supposed to "jam" the bracked into the gap on the valve cover. As for the 2007, I was unaware that the valve covers were any different...
Lee
Old Oct 27, 2006 | 09:10 AM
300HPGT's Avatar
wow you never Jam it between the valve cover and head. I just might take mine off because of the heat that is transfered from the head to the meter.
Old Oct 27, 2006 | 09:15 AM
eci's Avatar
eci
Lee
I'll take a pic. I didn't jam it into the gap where the valve cover "floats" over the head. I placed it on top, and ran the supplied bolt through it, through the loc washer.
On my car, it is impossible to lay the bracket flush on top of the mounting hole, as the 2007 has large ribs. The closest the bracket can get to the hole is about 1cm. Here is a pic:
Old Oct 27, 2006 | 09:33 AM
eci's Avatar
eci
In my 1st post I said jam it between the butresses. This does not imply between the valve cover and head. The ribs in my picture *are* the butresses. The mount supplied will not lie flush with the valve cover tab because of them.
Am I just not explaining this right? ARG!
Old Oct 27, 2006 | 10:58 AM
LeeB99's Avatar
No, you have made things perfectly clear now. In your first post, the description led me to believe that you were trying to slide the end of the bracket "under" where the bolt goes through the valve cover.
It is now obvious to me that there is a difference in the valve covers used in the 2007 GT's. We were unaware that such a difference exists, and are sorry if you feel that this makes our bracket "cheesy" or "poorly designed". We will check into this and make whatever change is necessary so that other '07 owners do not have the same issue...
Lee
Old Oct 27, 2006 | 11:10 AM
eci's Avatar
eci
Lee don't get offended. A good way to prevent this confusion would be to include directions with photographs. Sure, these are easy to install, but if I saw a photo of the MAF mount installed I wouldn't have had to scratch my head for a half hour wondering what I was missing! I could have then looked at the photo, said "woah", and called you guys.
Old Oct 27, 2006 | 01:46 PM
LeeB99's Avatar
I am not offended, I just had absolutely no idea that the valve cover on the '07 was different. You know, when we developed the street intake assembly (It was first displayed at the PRI show in early December 2004), we knew that if we did not supply an additional support bracket with the kit, that we were bound to get slammed by some people who over-analyze what they purchase. These would typically be the same people who believe that an cast inlet pipe is "just a big heat sink that makes the air hotter", which is completely false. Here we are almost 2 years later, and a couple of kits have recently been released that are basically the same as ours, and they do not supply such additional support. I am not aware that people are saying bad things about the fact that they are not supplying a bracket like we do.
Guess it is one of those ****ed if you do, ****ed if you don't situtations. We have never had anyone complain to us about the bracket before, and hopefully, the reason for this is because the '07 is different, and I will make sure that we fix this. Given the fact that a couple of people posted that they used it without issue, I will assume that people with the '05-'06 models are not experiencing problems...
Lee
Old Oct 28, 2006 | 11:30 AM
obofglob's Avatar
Alternative Auto in Michigan installed a C & L street intake on our 07 GT along with a dyno tune.
I am very pleased with the results. I just looked closely at the MAF bracket and on our car it fits perfect. It does not interfere with anything, it fits perfectly between the " butresses" on the valve cover and rest on top of the valve cover. I have taken pictures but have no idea of how to re-size them for the forum. I do not know if Alternative Auto modified the bracket but it does not appear so. Seems to be a very solid, clean , OEM look install.
Old Oct 28, 2006 | 11:41 AM
hightime2211's Avatar
Edit: If you have Win XP...
Download image resizer from http://www.microsoft.com/windowsxp/d...powertoys.mspx to reduce the image size.
Old Oct 28, 2006 | 11:53 AM
eci's Avatar
eci
It would be interesting to see a pic of your MAF mount versus mine. It is phsyically impossible for mine to fit.
