Delete Plate Install Question
Old Sep 24, 2008 | 03:32 PM
classix_stang289's Avatar
when im ready to pull out the injectors and fuel rails, what should i do to relieve fuel pressure so i dont make a big mess? Is there even much pressure at the fuel rail? the vehicle hasnt been started in a few days? whats the easiest and fasted way to relieve the pressure if need be?
Old Sep 24, 2008 | 03:38 PM
Thomas S's Avatar
You shouldn't have to worry about it. After around 30 minutes after turning off the car you should be fine. You don't need to disconnect the fuel rail btw. Just pull the injectors and lay the injectors/fuel rail over to the driver's side while you pull the intake. When you're done just flop the whole assembly back over.
Old Sep 24, 2008 | 04:24 PM
thanks buddy, before i tore into the vehicle i wanted to make sure i was prepared with this area of the install. thanks a ton
Old Sep 24, 2008 | 07:55 PM
Thomas S's Avatar
No problem man. It's easier than you probably think. Can't wait to hear what you think of them. Did you get a tune for them?
Old Sep 25, 2008 | 12:01 AM
LEO_06GT's Avatar
Follow this and you'll be alright.
http://forums.bradbarnett.net/showthread.php?t=452819
Old Sep 25, 2008 | 10:14 AM
Originally Posted by LEO_06GT
Yeah, I used that same write-up and the install came out perfect.
Old Sep 26, 2008 | 04:47 PM
yea, i have a brenspeed tune for the delete plates
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
Good Times
Aug 29, 2015 10:18 AM
