Data Logging
Old Feb 28, 2010 | 02:39 PM
colbymh's Avatar
Data Logging
Big thanks to Chris Rose @ Tillmans for setting me up and walking me through the data logging process. Pretty cool to watch whats going on. Looking fwd to him being able to tweak my tune even more.
Old Feb 28, 2010 | 03:03 PM
jp's performance's Avatar
it's nice to be able to do it on the tuner.love my new xcal-3 tillman tuned
Old Mar 1, 2010 | 05:05 AM
Old Mar 1, 2010 | 12:58 PM
70MACH1OWNER's Avatar
I am curious about one thing on this data logging process. Is there something (a sensor) in ours cars that measures A/F ratio? I mean if not how would CR know if he can make a tweek or not.
Old Mar 1, 2010 | 01:20 PM
colbymh's Avatar
Hopefully he will chime in cuz i cant speak with much knowledge about it. I told him that it smells rich on startup so I think there is base fuel values that can be adjusted. Also mentioned that I wanted more sensitivity with the pedal and a few other lil things.
I dont think A/F can be checked but im not sure.
Old Mar 1, 2010 | 01:36 PM
From the threads I've read, another O2 sensor has to be welded in and hooked to an A/F meter like a Dash Hawk.
Old Mar 1, 2010 | 02:02 PM
colbymh's Avatar
Makes sense otherwise they wouldnt do that on dyno runs.
Old Mar 1, 2010 | 09:56 PM
TillmanSpeed's Avatar
Former Vendor
We can still monitor dozens of other parameters and have the tune file nailed down perfect other than wide-open-throttle air/fuel ratio... which is something we can tweak if neccessary with dyno results.
We know on Colby (the OP), that he had his car dyno'd and it was approximately 13.4 from the tail-pipe sniffer which usually reads a little leaner than it really is. So he was probably about 13.1 air/fuel ratio up front (pre-cat, or lack there of for some of you ). We were targeting 12.85, so I added a tad of fuel, but it was nearly perfect mail-order.
Everything else can be dialed in, though. Spark, fuel trims, etc. They are probably all near perfect, too... but every car is different.
Colby, got your email but there were no datalogs attached. Shoot them over again, just in case they dropped off or something!
Chris Rose
Old Mar 1, 2010 | 11:42 PM
colbymh's Avatar
Dohhh, re-sent w files this time...
Sep 8, 2015 10:45 AM
tukatz
Aug 26, 2015 02:06 PM
Detroit Steel
2007-2009 Shelby GT500
Aug 17, 2015 02:29 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
kn7671
Aug 16, 2004 06:38 PM
