D-Spec question???
Old Aug 3, 2008 | 05:16 PM
08Bullitt0621's Avatar
D-Spec question???
Just installed Tokico D-specs and have a question on adjusting them. On the front there are chrome caps with a hole in the top. Do I insert the tool into this hole to adjust or do I take the chrome cap off and then adjust?
Old Aug 3, 2008 | 07:50 PM
RadBOSS's Avatar
My fronts have plastic caps (well onl y one is left), but perhaps they have changed the design? My rears have solid steel caps. Unless there is a access hole thru the center of the cap, then the cap may need to be removed so you can insert the adjustment tool, which is really just a fancy looking allen wrench.
Old Aug 4, 2008 | 05:41 AM
MaverickMLFD371's Avatar
yes remove the cap (steel or plastic caps) and insert the allen wrench tool into the top of the strut to adjust.
Old Aug 4, 2008 | 11:53 AM
scramblr's Avatar
+1......
Old Aug 4, 2008 | 06:25 PM
Thanks all the hole in the metal cap (front) threw me. The key chain tool fits in the hole...but wasn't doing anything.
Removed the cap and worked like a charm!
Old Aug 13, 2008 | 08:41 AM
R.A.F.A.L.E.'s Avatar
...and make sure you keep that key chain somewhere you'll find it back! I lost mine once and luckily found it at the very last minute. Was about to buy another one from Stang Suspension. They sell them for $29 I believe.
Old Aug 13, 2008 | 11:57 AM
scramblr's Avatar
Mine stays in the center console.
Old Aug 13, 2008 | 07:51 PM
mot250's Avatar
Its just a 3mm allen wrench with a fancy handle so you could put it on a key chain.
Old Aug 13, 2008 | 11:04 PM
Stoenr's Avatar
I wear mine around my neck.....
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
