D.S.S Racing is making 05 motors.
This is what i will probably do over the winter.
4.6 or 5.0 STROKER SUPER MODular Short Block
SUPER MODular (SOHC 2-valve GT)
NEW Level 10 Race Prepped 4.6 iron block with PRO-X Forged pistons,1.5 1.5 3mm SS50 U Molly rings with Tri Metal bearings, 4340 Forged H-beam rods with ARP 2000 rod bolts, Forged steel 8 bolt crankshaft. Rotating assembly is balanced to Racing tolerances. Bearing clearances are set and the short block is Professionally assembled in our climate controlled clean room. Includes FREE upgrade to ARP main studs and D.S.S. Main support System.,
4.6 Liter
$3599.95
Stroker 5.0 Liter $4199.95
SUPER MODular (DOHC 4-valve)
NEW Level 10 Race Prepped 4.6 Aluminum Cobra block with PRO-X Forged pistons,1.5 1.5 3mm SS50 U Molly rings with Tri Metal bearings, 4340 Forged H-beam rods with ARP 2000 rod bolts, Forged steel 8 bolt crankshaft. Rotating assembly is balanced to Racing tolerances. Bearing clearances are set and the short block is Professionally assembled in our climate controlled clean room. Includes FREE upgrade to ARP main studs and D.S.S. Main support System.,
4.6 Liter
$4899.95
Stroker 5.0 Liter $5499.9
Customer supplied Shortblock
SEND US YOUR COBRA SHORTBLOCK AND WE WILL CONVERT IT INTO A D.S.S. SUPERMOD SHORT BLOCK Includes Level 10 Race Prepping of your block PRO-X Forged pistons,1.5 1.5 3mm SS50 U Molly rings with Tri Metal bearings, 4340 Forged H-beam rods with ARP 2000 rod bolts, Forged steel 8 bolt crankshaft. Rotating assembly is balanced to Racing tolerances. Bearing clearances are set and the short block is Professionally assembled in our climate controlled clean room. Includes FREE upgrade to ARP main studs and D.S.S. Main support System., We arrange the pick up of your bare short block. Call for details (NOTE): your engine must be torn down to a bare short block before shipping.
4.6 Liter
$3899.95
Stroker 5.0 Liter $4499.9
2005 GT 4.6
NEW!
05 GT ALUMINUM
SUPER MODular (SOHC 3-valve)
NEW Level 10 Race Prepped 4.6 Aluminum 05 GT block with PRO-X Forged pistons,1.5 1.5 3mm SS50 U Molly rings with Tri Metal bearings, 4340 Forged H-beam rods with ARP 2000 rod bolts, Forged steel 8 bolt crankshaft. Rotating assembly is balanced to Racing tolerances. Bearing clearances are set and the short block is Professionally assembled in our climate controlled clean room. Includes FREE upgrade to ARP main studs and D.S.S. Main support System.,
4.6 Liter
$4899.95
NEW!
05 GT ALUMINUM
SEND US YOUR 3 Valve GT SHORTBLOCK AND WE WILL CONVERT IT INTO A D.S.S. SUPERMOD SHORT BLOCK Includes Level 10 Race Prepping of your block PRO-X Forged pistons,1.5 1.5 3mm SS50 U Molly rings with Tri Metal bearings, 4340 Forged H-beam rods with ARP 2000 rod bolts, Forged steel 8 bolt crankshaft. Rotating assembly is balanced to Racing tolerances. Bearing clearances are set and the short block is Professionally assembled in our climate controlled clean room. Includes FREE upgrade to ARP main studs and D.S.S. Main support System., We arrange the pick up of your bare short block. Call for details (NOTE): your engine must be torn down to a bare short block before shipping.
4.6 Liter
$3899.95
4.6 Liter
$3599.95
4.6 Liter
$4899.95
4.6 Liter
$3899.95
2005 GT 4.6
NEW!
05 GT ALUMINUM
4.6 Liter
$4899.95
NEW!
05 GT ALUMINUM
4.6 Liter
$3899.95
I will be one...........
I haven't had any experience with DSS or any other engine builder concerning modular motors but if you want to spend that kind of money it could be completed by one of the top 3 builders in the country. I have heard nothing but bad things about DSS from the racers at NMRA events. Ask 169stang about Boss330 (Al), Al is building his long block and will be building my short block. I have also heard bad news about making a stroker with a modular motor, to the tune of if you want more displacement then go to a pushrod motor, it will be cheaper/more reliable/faster.
How about if I drive the car up there and you guys do a complete install job? Might be better than trusting someone else to do it. There are several shops in my area that are just not worth a poot and I no longer turn wrenches.
Originally posted by Black Magic@October 26, 2005, 8:24 PM
Got to love it. Buy a new car, trash the motor, and spend another 5 grand to replace a short block. :scratch:
Also It is awesome to be in my garage working on my 05 and every nut and bolt is shinny with no rust.
Building a stronger shortblock is insurance to a much larger expense of blowing up the whole motor because something break,s in the lower end.
You could always buy a 60,000 ZO6 to run close to mine.
Or wait till you can buy a 75.000 07 Shellby.
I'm still way in cheaper than a Z06 and will be able to smoke em too.
roushcollection
7/28/15 02:08 PM
