Curious about some tires I picked up this weekend
Old Apr 21, 2008 | 04:22 PM
ShowGT's Avatar
Question Curious about some tires I picked up this weekend
I have spent some money for some tires from my GT and wanted to know if these will in fact work...................
I got a pair of 285/50/18 for the rear and 255/45/18's for the front
I found these locally on Craigslist of all places and paid $200 for all 4 with the stickers on them. The seller even gave me the warranty papers for them as well.
What do'yall think of this setup?
Old Apr 21, 2008 | 05:20 PM
RadBOSS's Avatar
Tire brand and model?
Old Apr 21, 2008 | 07:04 PM
Cavero's Avatar
A guy at the SCAA autocross event this weekend said the biggest he could fit was 275's but he might have been talking front only. I could swear there are people here running 285's. I know 255's will work no problem up front. That's what I'm running.
Old Apr 21, 2008 | 08:51 PM
2kanchoo's Avatar
Depends what kind of tires those are. Up to 275's will fit up front so you're good there. BUT if you have your car dropped 1.5" or more those rear's might not fit without rubbing around corners or over bumps. I have tires that are 28.8" overall height with a 1.5" drop and the only reason it doesn't rub is cause my suspension setup is so stiff. Mind you mine are 305's so being a 285 might be just thin enough to fit up in the wheel well.. maybe. Those tires would have an overall diameter of 29.22". I honestly didn't even know anyone made a tire with that much sidewall in 18".
I hope they fit for ya. If your car isn't dropped at all they will fit no problem. If so that's a great deal and it will give the car a badass rake.
Old Apr 21, 2008 | 08:56 PM
05GT-O.C.D.'s Avatar
I lust for a M24
I'm not a tire pro, but I'm running 255/35/20 up front and 295/30/20 in the rear w/ no issues and a 1.5" (FRPP) drop.
Old Apr 21, 2008 | 09:13 PM
2kanchoo's Avatar
26.96" overall height in the rear. That's a LOT less than 29.22.
Old Apr 21, 2008 | 10:58 PM
ShowGT's Avatar
Ok fellas, my bad here.
I got a set of Nitto NT 404's Extreme Force 285/50/18's for out back
and a set of Toyo Proxes T1-S 255/45/18 for the starting line out front.
No drop and no modifications to springs or anything else.
Old Apr 22, 2008 | 12:09 PM
ShowGT's Avatar
I am heading out to get these mounted, anyone have any advice this afternoon.............
Old Apr 22, 2008 | 12:28 PM
I lust for a M24
Don't scratch the rims.
Old Apr 22, 2008 | 01:15 PM
jayguy's Avatar
I'm wondering if the 285's will fit a stock rim. I'm sure they can force them on, but isn't that pushing it a little? Or do you have wider rims? Post up some pics when you get a chance, let us see how they look.
I've got 255's all around on my fanblades, but have been thinking wider tires for the back would be nice, as these don't seem to have enough grip.
Old Apr 22, 2008 | 03:00 PM
SoundGuyDave's Avatar
The 285 in a 50-format is going to be one TALL tire out back, about 1" larger in diameter than the stocker... 285/40 is the stock diameter. Also, for general knowledge, a 285/40 on an 18x9.5" rim with a +50mm offset will fit on front, even lowered 1.25". It BARELY clears the strut housing, but fits well within the fender, even at full lock. I really don't think that the 285 will fit on a stock wheel, you really need at least 9" of rim width, and should have 9.5" width for proper fit. Not sure, but I would bet that the 285/50 on a stock wheel will look like a balloon, and handle about as well...
Old Apr 22, 2008 | 06:38 PM
RadBOSS's Avatar
I would strongly recommend not mixing tire brand or tire models with in a brand. Can lead to stability problems at speed when side wall stiffness is not the same. Differential sizing front to rear has some risk of that, but brand and model change more so because of the differences in tire design and construction.
The 285's probably want a 9.5" - 10" wide wheel
Old Apr 22, 2008 | 09:22 PM
ShowGT's Avatar
Old Apr 22, 2008 | 09:24 PM
ShowGT's Avatar
I got these mounted and balanced with no issues whatsoever. I am running an 18x9.5 rim which fit very nicely. I like how to wheel wells are filled and the rake as mentioned above is simply stealth looking. I posted the above photo to show the overall width on the rear.
Old Apr 22, 2008 | 09:43 PM
2kanchoo's Avatar
I'm glad you had the proper size rims! That turned out sweet!
Old Apr 22, 2008 | 09:46 PM
JonCo's Avatar
that looks manly as heck
Old Apr 22, 2008 | 10:27 PM
atomic_il's Avatar
wow that really worked out for you, nice!!
dohc97
17
Sep 10, 2015 09:21 AM
pretender
Aug 24, 2015 01:59 PM
tony2014mustang
Jul 23, 2015 10:56 AM
