Cold Air Intake for 2005
Check this out! This Company claims to have a CAI that delivers impressive performance without a tune. A 15 HP gain across the entire RPM band and impressive torque also.
www.cnlperformance.com
I`m not sure what the cold air kit being aluminum has to do with the heat. My concern though is that the maf sensor "fools" the computer that it is running richer than it is.So the air fuel ratio is actually 12:1 instead of 11:1. What happens if you flash tune your car? Will the computer run the mixture to lean ?
Sorry, I didn't realize there was a seperate thread about this. I was just surfing and found it. I will post any additional info in the correct thread.
http://forums.bradbarnett.net/index.php?showtopic=11706
