coilover drop springs?
check out ground control. i have the front and rear kit from them. you can use stock struts or they will sell you koni's. mine work great. i used the stock struts but will be replacing with a drag strut as soon as they are readily availible. ground control also has camber plates for 05-up.
i have a bunch of questions for you is there anyway you could call me sometime or i could call you so i can pick your brain on the ground control kit?
yeah technically it is but the aftermarket ones use a 2.5" dia spring that comes in tons of different spring rates for adjustability+you can set ride height. the rear for the 05 is not a coilover shoch though. there isn't enough room on the 05 to get a proper fit for a coilover. they use an adjustanble lower mount and the spring is in the stock location. really nice stuff.
