Code P2106 and P2135 TSB information, wrench light
Old Nov 30, 2005 | 07:18 PM
Doug@C&L's Avatar
Hey guys,
I've found some new information on a TSB for the code P2106 and P2135 from Ford. Just thought I'd pass it along. Sorry if this has already been posted....
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
Publication Date: June 30, 2005
FORD: 2003-2005 Thunderbird
2005 Crown Victoria, Mustang
2004-2005 Explorer, F-150
2005 E-Series, Expedition, F-Super Duty
LINCOLN: 2003-2005 LS
2005 Town Car, Navigator
MERCURY: 2005 Grand Marquis
2004-2005 Mountaineer
This article supersedes TSB 05-09-15 to update the Issue and Dealer Coding.
ISSUE:
Some vehicles built 11/29/2004 and prior may exhibit the wrench light on with both P2106 and P2135 diagnostic trouble codes (DTCs).
ACTION:
Replace the throttle position sensor (TPS) following the instruction sheet included in the TPS service kit. Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B36.11 and higher, or B37.2 and higher. This new calibration is not included in the B37 CD. Calibration files are also available at www.motorcraft.com.
CAUTION: FAILURE TO FOLLOW THE TPS REMOVAL AND INSTALLATION PROCEDURE WILL RESULT IN DAMAGE TO THE TPS SCREWS.
PART NUMBER PART NAME
3L5Z-9B989-AA TPS (Kit)
Thanks, Doug.
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
Mrmiles1369
Sep 11, 2015 07:23 PM
14Glassback
Sep 11, 2015 04:50 PM
haitham
Sep 8, 2015 12:52 PM
SMOKE46
Sep 6, 2015 09:40 PM
