CMCV'S ? help.
Old Dec 29, 2008 | 01:58 PM
mike2005GT's Avatar
CMCV'S ? help.
I have a SCT tuner for my 2005 gt. It has the option to turn off the cmcv's, my question is if I turn them off do they stay off in the open or closed position ?
Old Dec 29, 2008 | 02:03 PM
70MACH1OWNER's Avatar
If you have not replaced the stock plates with a set of deletes than you "do not" want to turn them off. I really am not sure about them staying open or closed but my guess would be closed. When you turn them off you are deactivating the motor that controls them.
Old Dec 29, 2008 | 03:50 PM
08VistablueGT's Avatar
Yeah, I would definitely not risk it. What if they stay closed while at WOT...?
Old Dec 29, 2008 | 06:05 PM
classix_stang289's Avatar
i think i asked brenspeed this a while back and i think they said that you use that option if you changed the plates and its the only mod you have on the vehicle. But dont quote me on that cause im not sure, sorry.
Old Dec 29, 2008 | 06:07 PM
if you use this option be careful cause if you try and change it back to stock setting with the plates still in, those plates can get "stuck" in whatever position they are in whether they are closed/open,half open. be careful and good luck with whatever you choose to do
Old Dec 29, 2008 | 07:47 PM
travelers's Avatar
They will stay closed. and what SCT tuner do you have that you can turn them off? None that I was aware of?
Old Dec 29, 2008 | 07:57 PM
mike2005GT's Avatar
I have a sct livewire tuner. and it's in the user adjustable options.
Old Dec 29, 2008 | 08:01 PM
travelers's Avatar
Nice but you need to replace your stock ones with the ones that are the delete plates.
Old Dec 29, 2008 | 08:14 PM
mike2005GT's Avatar
I was hoping that I could turn off the cmcv in the open pos. and avoid pulling the intake.
Old Dec 30, 2008 | 04:36 PM
how are you going to be able to make sure that the plates are actually in the open position when you turn it off? i dont know if you can unless you physically check to see they are open when you shut it off.
plus becareful also because i heard a story of one of these cars, that one of the butterflys fell off the plate and boom goes the motor, so please try to avoid something like that from happening.
Old Dec 30, 2008 | 04:38 PM
try on the back of the plates, i think there is a lever to manually open and close the plates. maybe wedge something in there so the plates are stuck open and then use the sct to turn the motor off. i have heard stories of people doing that, wether it was a success or not i dont know. good luck with whatever you decide.
Old Dec 30, 2008 | 04:50 PM
LEO_06GT's Avatar
Or stop being cheap and buy the the $120 part if you really want to have delete plates. Why risk your engine over $130?
Old Dec 30, 2008 | 05:34 PM
correct indeed. well said.
kennyg
Aug 14, 2023 11:45 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Kalel08
Sep 29, 2015 03:06 PM
dakotawolfe
Aug 26, 2015 04:01 PM
missc1115
Aug 26, 2015 07:56 AM
