Clutch/Flywheel question
Old May 30, 2010 | 06:21 PM
Whosit's Avatar
Hey guys.
I blew my clutch at the drag strip this weekend. I am thinking of going with the Spec Stage 2+ from American Muscle.
http://www.americanmuscle.com/spec-s...gt-clutch.html
I am also replaced the pilot bearing and flywheel. Should I go aluminum or steel? The car is driven weekends with some drag time.
Opinions/suggestions?
Thanks!
Old May 31, 2010 | 06:10 AM
Whosit's Avatar
Someone mentioned to me to stay with a steel flywheel since it's easier to stall with an aluminum one. Just want to make sure I do this right.
Old May 31, 2010 | 08:56 AM
Whosit's Avatar
Anyone?
Old Jun 2, 2010 | 07:01 AM
Tim, I'm running a Centerforce DF with a Fidanza aluminum flywheel (along with a Coast DS and 4.10 gears).
It definitely needs a little more finesse off the line, but once you get it down, it does get up and go!
Another thing I noticed recently, when running the A/C and coming to a stop, the rpm's dip to around 400-500 then back up to normal. I'm guessing this is because of the aluminum flywheel. The flywheel doesn't have enough rotating mass with a load (like the A/C) compared to the stock steel unit.
Old Jun 2, 2010 | 01:32 PM
05bluestang's Avatar
I'm running a spec 3+ with the spec aluminum flywheel. Took some getting used to but once you get the hang of it its all good. Engine spinns up alot faster but you also have to keep the rpm up since you don't have as much rotating mass as with steel flywheel when you shift.
Old Jun 2, 2010 | 06:31 PM
tom281's Avatar
I used a Spec 3+ with steel flywheel and a Ram hydraulic slave cylinder. I had no complaints, it was a heavier pedal feel but not obnoxious. At the time, any Spec less than a 3 was getting bad reviews, so that's why I did the 3 then figured might as well upgrade to the + series.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
