Clutch : which brand
Old Jun 21, 2010 | 02:24 AM
kawazakske's Avatar
Okay,
Since a few days I've got an E-force SC and Steeda driveshaft. Especially cause I'm doing some trackdays , I aspect the clutch will start to fail. What 's the best replacement clutch I can buy ?
Thanks,
Peter
Old Jun 21, 2010 | 08:43 AM
WarpdSpazm's Avatar
I was very happy with my RAM HDX clutch in my '06... Pedal feel was very close to stock (slightly stiffer) and took quite a number of 3K launches at the track.
Old Jun 22, 2010 | 08:47 AM
shanec's Avatar
My stock clutch started slipping 3 months after the E-Force went in.
I am happy with my Centerforce DFX wtih Centerforce Flywheel. I might not have needed a new flywheel, but I did it anyway just for peace of mind.
The clutch pedal is firmer but not real stiff. Engagement is pretty quick, but not an on/off clutch. You will have to adjust the way you start off in 1st gear because it engages much faster than stock. You have to be a little quicker on the throttle once the car starts rolling forward.
I am going back soon to put in an FRPP clutch line. This is a steel clutch line to replace the plastic one that comes stock. With the increased hydraulic pressure from an aftermarket clutch and ordinary engine heat, the plastic one can baloon and crack, causing air to seep into the throwout bearing which makes bad things to happen. This doesn't happen to everybody. But again I'm upgrading mine for peace of mind.
It would be good to do this at the same time the clutch is put in.
Old Jun 23, 2010 | 12:09 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
ACT is a good clutch, RPS is good but can be costly(stay away from the dual carbon) and i've heard good things about Spec.
Old Jun 23, 2010 | 07:33 AM
69Mach1-409's Avatar
I believe JPC in Baltimore carries a SS line that is much cheaper then FRPP.
Old Jun 23, 2010 | 09:42 AM
kawazakske's Avatar
Thanks,
In second gear the clutch is already slipping when I put put the pedal to the floor so I ordered the Spec stage 3 clutch and flywheel; Hopefully it will do its job properly
Grts
Old Jun 24, 2010 | 11:41 AM
Dysan's Avatar
I've got the Spec 3+ in mine and it works quite well. I do hope you got the "low pedal requirement" though. I've seen some people have had problems with their slave cylinder failing after putting in the regular 3+ which I believe is due to the extra pressure it needs. With the low pedal requirement it's just about as light as the stock clutch was.
It will take a good 500-700 miles to get it broken in though so be prepared for it to be rather touchy until then.
Old Jun 24, 2010 | 02:13 PM
tom281's Avatar
Spec 3+ is what I had good success with, supporting a Saleen blower, etc.
Old Jun 25, 2010 | 12:50 AM
kawazakske's Avatar
Euh, low pedal requirement ???
Gill5oh
Oct 6, 2017 10:50 PM
CiniZter
25
Apr 28, 2016 05:41 PM
MustangConvert11
Sep 30, 2015 08:01 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
