clocking altenator on saleen sc install
Old Jun 25, 2008 | 07:15 PM
gpp's Avatar
gpp
if i read right the reason for clocking the altenator on the saleen super charger install is the hot wire tends to rub if you dont.if this is the case why not just get a longer hot wire?if this isnt the reason why do you have to do it and does it have to be done.
Old Jun 25, 2008 | 10:49 PM
RedFire281's Avatar
Legacy Supercharged Tms Member
I didn't clock mine and its been installed for about 2 years ... and I haven't seen the cable rub against anything.
Old Jun 26, 2008 | 06:29 AM
Darth Stang's Avatar
I thought you had to clock the alternator to release te pulley so it didn't need to be turned arund to work properly. I think the pulley is one way stock.
Old Jun 26, 2008 | 03:26 PM
Robbieg's Avatar
You don't need to clock the alternator and nowhere in the directions that I got with mine did it say to do so. It does come with a cable to extend the hot cable because the factory cable is to short in the new position.
FromZto5
75
Oct 5, 2015 02:27 PM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
