Check Engine Light On
Old Jun 16, 2007 | 10:35 PM
TorchRedV6's Avatar
Ok, so today I took off my JLT intake and returned my car to the stock tune as I am trying to sell those parts. Well, it drove just fine for an hour or so and then the check engine light cam on and I'm not sure why. I plugged all the sensors back in correctly and it is running normally.
Anyobody got any suggestions as to what to do? Can I trouble shoot it with my XCal 2? Any help would be awesome.
Old Jun 16, 2007 | 10:49 PM
Lime GT's Avatar
You should still be able to read codes with your xcal2.
Old Jun 17, 2007 | 01:37 AM
DynamicmustangGT's Avatar
Try reading it if not to the dealership to have them fix it. It's back to stock so they probably won't know.
One question though. How come your name is torchredv6 and you have a black car pictured and a black car?
Old Jun 17, 2007 | 10:34 AM
06GT4RAD's Avatar
Retrieve the DTC codes with the X-Cal and see what they are.
Richard
Old Jun 17, 2007 | 04:52 PM
ski's Avatar
ski
Make sure the MAF sensor's rubber gasket is reinstalled, the MAF sensor is securely mounted, the vacuum hose is installed on the intake immediately upstream of the throttle body, the intake has not come loose from the throttle body or the air box, and retighten the stock intake's clamps.
Ecostang
Nov 3, 2022 08:50 PM
STOERKEL
Sep 11, 2015 11:38 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
