Check engine light
Old Oct 19, 2005 | 06:43 PM
nyyankee's Avatar
Will installing the Bassani off road X-pipe give you a check engine light?
Old Oct 19, 2005 | 07:56 PM
JeffreyDJ's Avatar
You'll need mil eliminators to prevent the check engine light from coming on.
Old Oct 19, 2005 | 08:04 PM
dustindu4's Avatar
9 is not my lucky number.
What he really needs is an SCT tuner to turn off his rear O2 sensors. You might as well take the plunge and do it man. It's worth getting a tuner by itself anyway, huge gains. Buy it from bamachips or Brenspeed and if you tell them what mods you have, they will custom make a tune for you and email it to you.
Old Oct 19, 2005 | 08:19 PM
JeffreyDJ's Avatar
True, that is the best solution. As long as he wants to spend the money to do it. But MIL eliminators are only going to set him back $29. Decent short term solution.
But, the tuner would be best bet, true.
Old Oct 20, 2005 | 08:46 AM
I8URVTEC's Avatar
Yes it will turn the CEL on however it won't be on all the time. I had that problem with my Bassani's but since the computer does adjust sightly to fix the A/F ratio sometimes the light would be on and sometimes not. I had Ford run the codes and they said it was lean but not bad and I could tune it if I want to fix it. I had a dyno tune done to fix the A/F and no more light (knock on wood). They did not turn off the 02 sensors but rather just adjusted the A/F. Here is more info on it:
http://franksperformance.com/Forums/index....&st=0&#entry504
Old Oct 20, 2005 | 01:57 PM
TerpGT17's Avatar
I have the Bassani's with hi-flos(not installed yet) and I was wondering if that would still trigger a CEL. I'm aware that a custom tune would get the most out of the car, but would it run fine and still benefit the car performance wise if I just installed it now?
Old Oct 20, 2005 | 02:23 PM
JeffreyDJ's Avatar
Well, I spok with NYYankee about it,a nd can find no info regarding MIL's for S197's ... So.
You'd be better off either way with a tune after switching exhuast out, but unless you really mess with the a/f ratio, you probably won't be badd off, just won't see as much improvment as you would otherwise.
Ecostang
Nov 3, 2022 08:50 PM
STOERKEL
Sep 11, 2015 11:38 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
