check engine light
installed bassani x-pipe with hi flow cats and mufflers . started up ok no check engine light . went in house cleaned up. came out started up check engine light on. cleared with predator . rided around 10 miles no light , started up again check engine light came on. what to do?
You might be flowing too much air now with the high-flow cats... check with Diablo to see if high-flow midpipes are covered under the "stock" 91 tune.
Second option is the high-flow cats aren't cleaning the air enough for the rear o2 sensors... I would think this would take longer though, not a quick CEL like you experienced.
Originally posted by Faber@April 12, 2005, 4:10 PM
unplug the negative battery cable and let it sit overnight.
that took care of it for me.
Originally posted by black gt 2005+April 12, 2005, 10:02 PM--><div class='quotetop'>QUOTE(black gt 2005 @ April 12, 2005, 10:02 PM)</div><div class='quotemain'><!--QuoteBegin-cdemot02@April 12, 2005, 5:49 PM
Turn the Rear 02s off.
[/b][/quote]
with the tuner
ClayP
8/11/15 06:23 AM
