Check-Engine & Electronic Throttle Control lights came on
Old Sep 9, 2007 | 08:31 PM
MrClean's Avatar
After I reinstalled the C&L CAI & Tune, (she'd gone back to stock for front strut mount TSB), the car started right up and idled fine, but when I took her for a run, she bogged down and the engine died...and the Electronic Throttle Control and Check Engine lights came on. This happened 3 times, each time I was able to start her back up, and I got home.
I then re-loaded the tune, and took her for a short test drive with no problems, stopped her, then took her for a longish test drive (5 miles) with WOT and speeds....well let's just say I was happy I didn't run into the law. No more probelms....maybe the tune just didn't load properly the 1st time? I have all the tools and the stock airbox in the trunk to return to stock if I need to... comments?
Old Sep 9, 2007 | 09:37 PM
theedge67's Avatar
Strange things happen sometimes when loading tunes. Rare, but they do happen. As long as it doesn't come back...no problem.
Old Sep 10, 2007 | 05:08 AM
MrClean's Avatar
Thanks Steve. I like your sig...what does "mileage warranty delete" mean?
Old Sep 10, 2007 | 05:56 AM
Mach's Avatar
You may wish to read this thread also... Helped me...
http://forums.bradbarnett.net/showthread.php?t=70401
Old Sep 10, 2007 | 06:27 AM
travelers's Avatar
+1 on the oddities. Some times you have to go back to stock and then back to you good tune.
Old Sep 10, 2007 | 10:26 AM
theedge67's Avatar
Mileage Warranty Delete = 50,000 miles in 2 years. Warranty gone due to miles.
Old Sep 10, 2007 | 12:13 PM
MrClean's Avatar
Thanks , I remember reading that thread, and that's actually the 1st thing I did...check everything was tight (in fact I tend to overtighten stuff!)....everything was good.
Drove into work today 30 miles, and no problems. I guess an "oddity" happened the 1st time I'd reloaded the tune.
Thanks for weighing in!
14Glassback
Sep 11, 2015 04:50 PM
M3hunter
Sep 10, 2015 09:26 AM
Sep 8, 2015 10:45 AM
