Charge Motion Plates?
Old Mar 23, 2005 | 12:00 PM
Redfire 05Gt's Avatar
Ok, so, Charge Motion Plates...what exactlyare they? I know they're part of the intake system. What do they do?
I've seen Steeda's part number 555-3125 referred to as "Charge-Motion Plates" and also "ChargeMotion Delete Plates". Which is correct?
-Dan.
Old Mar 23, 2005 | 12:29 PM
DraftHorsePower's Avatar
i believe they increase the amount of airflow in the intake path.
Old Mar 23, 2005 | 12:48 PM
RRRoamer's Avatar
My understanding is that the charge motion plates have a throttle valve (just like a carborator) that partially blocks the flow of air through one of the intake valves of each cylinder at low speed (I believe it is below 3500 rpm). This causes one intake to have much higher velocity and gives better cylinder scavaging and mixture distribution at low speed, which leads to better low speed torque and fuel economy.
The down side is that the shaft is still in the intake track at high engine speed, which costs you some power on the top end. Getting rid of the valves leads to better top end power at the cost of worse low end power. Take your pick.
Old Mar 23, 2005 | 01:19 PM
nynvolt's Avatar
Interesting for all the Honda bashing that goes on in many Mustang forums, Ford has implemented what amounts to basically the same Vtec used in the Honda civic EX and same variable intake found in an acura RSX type S on this new Mustang.
Pretty cool technology.
Old Mar 23, 2005 | 01:31 PM
05YellowGT's Avatar
Talking
I got the first set that Steeda released and they did a dyno pull after installing them. I picked up 6RWHP , but only 1RWTQ with them. The dyno sheet didn't show any low end torque loss and the car doesn't feel like it either. With the plates my air/fuel ratio went from about 12.0 to about 12.9 , so I am taking more air in with the plates. I think once they release the headers and I get more flow out the rear , I should see a better increase from the plates ...
Old Mar 24, 2005 | 12:19 PM
jwede's Avatar
Ford has been using this technology for quite some time. My 97 SHO had secondary intake runner controls that would open a second set of butterflies afte 3500 RPM. I know of a couple people that have just removed them. The pre-V8 SHOs has two sets of runners, one long and one short for different RPM ranges.
Old Mar 27, 2005 | 03:36 PM
Crash's Avatar
Ya, but back then Yamaha built the intake systems... LOL!
kponypower
Jun 17, 2020 07:17 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
DrVet
Sep 23, 2015 01:48 PM
14BlackGT
Aug 28, 2015 02:56 PM
