Changing Diff an Trans Fluid
Old Sep 14, 2006 | 05:07 PM
max2000jp's Avatar
First, my car has 23K miles on it and is 19 months old. What is the maintence interval for both the transmission and differential fluids? Lastly, what's everyone using?
Thanks, Jason
Old Sep 14, 2006 | 06:37 PM
theedge67's Avatar
Scheduled maintence guide suggests 150,000miles for diff. fluid and automatic transmissions, nothing for manual tranny's. The guide stops at 150,000 so not sure about the manual tranny's interval, obviously it's way longer than you need to worry about right now.
As far as what to use, just use the motorcraft stuff, it's fully synthetic...good stuff.
Old Sep 14, 2006 | 06:52 PM
65sohc's Avatar
Excellent advice. I used to own a 94 Supra Turbo, the owners of which cars are even more mod-obsessed than Mustang owners. I don't know how many dozen transmissions, including mine, were ruined by deviating from the factory recommended lube (which was also synthetic) and using Redline synthetic gear lube in the hopes of some magical transformation in "feel" or performance.
Old Sep 14, 2006 | 07:08 PM
theedge67's Avatar
Exactly. The engineers who designed these parts spent countless hours designing these parts to be used with certain lubrication qualities. If the stock oil was crap, you'd have tons of failures, and Ford would be spending even more $$ on expensive warranty work. Sometimes "better" oil can be worse...
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
southern stang
Sep 26, 2015 04:19 PM
Airborne42
Sep 24, 2015 10:27 AM
