CEL and codes on startup - 2770, 2771, 2772
Old Apr 23, 2006 | 12:58 PM
TexaStang's Avatar
Anyone know what these are?
Old Apr 23, 2006 | 01:06 PM
don_w's Avatar
What letter do they start with?
Old Apr 23, 2006 | 02:05 PM
TexaStang's Avatar
Sorry, P2770, P2771, P2772
Old Apr 23, 2006 | 02:34 PM
don_w's Avatar
<div class='quotetop'>QUOTE(TexaStang @ April 23, 2006, 1:08 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Hmmm, I did some googling on OBDII codes, and I can't find those listed anywhere. [img]style_emoticons/<#EMO_DIR#>/headscratch.gif[/img]
Old Apr 23, 2006 | 03:28 PM
Fazm's Avatar
not sure bout fford, but most makes p27xx codes have something to do with the torque converter.
Is your car an automatic?
(p2770 code usually means you have a TCC solenoid that has gone bad or wire pinched/cut)
If you dont have an automatic, then thats an issue. Cars throwing pcm codes that dont exist is usually a sign of the ecm/pcm going/gone bad.
EDIT: try resetting them and see if they come back at all
Old Apr 23, 2006 | 05:27 PM
TexaStang's Avatar
It's a manual. I googled them and found something about automatics, so that was weird. I reloaded my tune and it went away and hasn't come back.
Old Apr 23, 2006 | 08:32 PM
jvm051's Avatar
P2770 Torque Converter Clutch Circuit High
P2771 Four Wheel Drive (4WD) Low Switch Circuit
P2772 Four Wheel Drive (4WD) Low Switch Circuit Range/Performance
Interesting, Ford is making the Mustang in a 4WD version now. Hopefully your reloading of you tune gets rid of it.
http://www.myscantool.com/dtc/powertrain.html
Old Apr 24, 2006 | 10:06 AM
Fazm's Avatar
ok, as long as they dont come back you are gonna be fine. If they come back, id be worried bout the pcm.
May 3, 2026 05:42 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
haitham
Sep 8, 2015 12:52 PM
