CDI location
Old Jan 9, 2005 | 08:18 PM
legend05's Avatar
It would have been nice if they had the air "supply" come from under the bumper spacing to the top where the CAI filter is. I really havent taken a good look at the amount of space for an air dam extension. But if there is room, i will certainly try fabricating something. The more air the better i guess. If i'm wrong let me know
Old Jan 9, 2005 | 08:28 PM
SVTJayC's Avatar
If it's cold air you are right...If it's hot air, you are wrong...
Looks like with that setup you'll be breathing in some nice 200+ degree air. First thing i would fab up, is a heat shield.
Old Jan 9, 2005 | 08:53 PM
legend05's Avatar
I was thinking more of this location or just below that bumper line.
I myself may be going shaker but this would be great for those who want to stay stock but want better air flow.
Old Jan 9, 2005 | 09:14 PM
PONY XPRESS's Avatar
Been there, done that.
http://forums.bradbarnett.net/index.php?showtopic=12644
Old Jan 9, 2005 | 09:30 PM
legend05's Avatar
Right on pony!!! Great job. It seem like the way to go for more forced air.
Keep us informed
Old Jan 9, 2005 | 09:44 PM
2005MustangGT's Avatar
check out the "lower grill delete" forum....could definetely work for what you are looking for
Old Jan 9, 2005 | 10:17 PM
Keep us informed
Without a hood scoop or going through the headlamp I see only one other spot to get air, but it is marginal.
If you look at the left fender where the stock box mounts you will see a triangle cut out in the fender. This exposes the inner fender. My thinking is maybe Ford has future plans for picking up air. You could cut out the inner fender & catch air there, but the down side is heat off the wheel assembly & dirt. So you would have to screen the duct.
Anyway maybe I will try to make a nicer duct system out of hard plastic, or maybe a big name company will beat me to it.
Old Jan 10, 2005 | 05:15 AM
DozerzPony's Avatar
I was reading in a magazine that the only thing you should not is tey to aspirate the front grille...thay said something about changing it would hurt the aerodynamics because they had to tweak some stuff to make the overbite nose work.
Old Jan 10, 2005 | 07:19 AM
legend05's Avatar
Pony, I think all this works calls for an easier measure. TURBO!!!. lol
But you got the right idea. Triangle in fender? Modded fender grilles baby.
oneeyedgiant
Nov 16, 2015 12:23 PM
RoushRS3
Sep 29, 2015 08:03 PM
TerryD
Sep 28, 2015 11:48 AM
