caster camber plates
Old Nov 18, 2005 | 04:29 PM
05passion's Avatar
i had a missshap with the 05 and hit a BIG pothole now the camer is off and cannot be adjusted without these parts ,i am hoping someone can give me some info on where to buy and what is the best for the money
Old Nov 18, 2005 | 06:22 PM
Moondog's Avatar
Try Steeda - also - use the search function - I think Ford has part number out.
Old Nov 18, 2005 | 07:12 PM
LordBritish's Avatar
How do you know your camber is off?
Old Nov 18, 2005 | 07:35 PM
Import-Slaya's Avatar
Eibach has a set of camber bolts now, for about $30 or so. http://www.seanhylandmotorsport.com/online...roducts_id=1805
I've also heard good things about the camber bolts from this company: http://www.specprod.com/
Old Nov 18, 2005 | 08:35 PM
thump_rrr's Avatar
Caster cannot be adjusted on the 05's.
IF YOUR CAMBER HAS CHANGED YOU HAVE SUSPENSION DAMAGE. GET IT TO THE DEALER FOR A CHECKUP QUICK.
If it's toe change it can be adjusted. You may have just bent a tierod
Old Nov 19, 2005 | 02:32 AM
05passion's Avatar
it has already been to the dealer that is how i know it needs the parts ,they had to order theres also so i thought i would check and see if there was something better in the after market be fore proceeding!!
Old Nov 19, 2005 | 09:55 AM
If your camber is off, doesn't that mean that something is bent?
If something is bent, it's best to replace the bent part rather than try to compensate for it.
Old Nov 29, 2005 | 09:01 AM
rony1976's Avatar
can anybody say if the pro-alingment kit from Eibach works? I rather spend $30 than almost $200 from Steeda...
Old Nov 29, 2005 | 12:32 PM
FinlayZJ's Avatar
If your camber is off, there is a piece of your suspension that is bent. Getting a camber bolt or plate is just a band aid to the problem.
If your car was in a wreck, and the frame/unitbody was bent, would you just repaint the car? No. So why do it in this case?
Old Dec 5, 2005 | 02:49 PM
rony1976's Avatar
Sean Hyland doesn't carry the Eibach Pro-Alignment kit anymore.. I can't find it anywhere else for the $30 that they advertised it for... has anyone seen it elsewhere?
Old Dec 5, 2005 | 03:03 PM
rony1976's Avatar
I just checked with Eibach, and the part number 5.81260K fits a range of vehicles, different make/models. If you do a google search, you'll be able to find it and just order it even if it's for a different application than the 05 mustang GT.
I just ordered one, I'll post the results.
Old Dec 5, 2005 | 03:33 PM
AussieMustangGT's Avatar
Rony you can get the Eibach Alignment kit from here: http://www.mustangextras.com/index.asp?Pag...ROD&ProdID=2097 it's $18.99, I bought one from them, I bought it for when I lower my car with the Eibach Pro Springs, I'm also going to order a BMR panhard bar.
Hope this helps
Antigini-GT/CS
Oct 5, 2015 09:43 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
MRGTX
Aug 15, 2015 07:45 PM
killaz05
Jul 24, 2015 08:49 AM
