Carbon Fiber Drive Shaft
Old Aug 29, 2005 | 12:31 PM
TKEUofM's Avatar
Check this baby out! It's down near the bottom of the page.
http://www.bmrfabrication.com/2005Mustang.htm
Here's the description.....
BMR carbon fiber driveshafts provide a variety of benefits for your '05 Mustang. The overcomplicated factory two-piece shaft weighs an unbelievable 42.3 lbs. as compared to our 20.7lb. one-piece carbon fiber replacement. This rotational weight reduction alone is responsible for gains of 15+ rear wheel horsepower. Additionally the benefits of carbon fiber can be felt and heard in reduced driveline harmonics and vibration. Carbon fiber absorbs these harmonics much more efficiently without the long term fatique associated with steel or aluminum. The factory driveshaft is rated at an estimated 450-500rwhp while we rate our carbon fiber shaft up to 1000+ rwhp.
BMR's carbon fiber driveshaft comes with a new billet 4340 pinion yoke and a billet 7075 front flange both using heavy duty 1350 series u-joints. The carbon used in these shafts has two distinct wind angles to provide the most unparalleled torsional rigidity(45 degree wind angle) without sacrificing linear strength(15 degree wind angle). Shipped complete with new pinion nut, u-bolts and instructions. NOTE: Rear pinion flange requires professional installation.
Old Aug 29, 2005 | 12:34 PM
MaverickMLFD371's Avatar
Available for $1,100 on LMPerformance. Great Mod, 15 horses with some weight reduction. But $1,100, not my cup of tea.....
Old Aug 29, 2005 | 12:37 PM
auto4's Avatar
Very nice, very expensive!
Old Aug 29, 2005 | 12:40 PM
TKEUofM's Avatar
Very true about the cost.
I guess this is what you buy if you actually have money left over after buying a CAI, Tuner, Gears, Pulleys, Rims, Stripes, Springs, Control Arms, Sway bars, shifters, x-pipes, headers and stereo equipment............
I sure wish money grew on trees..
Old Aug 29, 2005 | 12:48 PM
GhostGT's Avatar
It does...
Old Aug 29, 2005 | 12:56 PM
TKEUofM's Avatar
:dance:
YES!!! IT DOES EXIST!!!! WOOHOOO.
I need a seedling for my backyard.
Old Aug 29, 2005 | 01:01 PM
LordBritish's Avatar
I like that.
15+ RWHP and -20 lbs is good.
Who has that installed.
I want it.
Old Aug 29, 2005 | 01:31 PM
Maybe if they brought it down to a good $400-600, then I maybe consider it.....
Old Aug 29, 2005 | 02:34 PM
Rampant's Avatar
Don't forget, that is rotating mass, so a reducing of 20lbs. is quite a bit. Should help the engine rev a lot quicker as well.
Still not sure if it is worth that price though, especially since it will require professional installation.
Old Aug 29, 2005 | 02:41 PM
mystic cobra's Avatar
If you plan on getting a supercharger in the future it might be a good investment.
Old Aug 29, 2005 | 03:04 PM
I'd get it if it was $700.
$300 for proffesional install and we're looking at around $1000 total. Not that bad if it was priced at $700.
Old Aug 29, 2005 | 03:33 PM
dhof303's Avatar
169Stang just bought one and is getting it installed currently, he had some problems with the factory carrier bearing after several hard launches. I love the idea of this mod but right now it seems out of reach for me. Most likely the cars getting this one will be factory or corporate funded/sponsored race cars. Doesn't change the fact that I want one though.
Old Aug 29, 2005 | 03:38 PM
MilStang's Avatar
I will be interested in hearing the results on this one.
Old Aug 29, 2005 | 03:49 PM
scrming's Avatar
Well perhaps if i drop my current one... LOL!
Don't know if the GT's have the same sticker...
Old Aug 29, 2005 | 03:59 PM
Sonic05's Avatar
When you've bought everything else there is to buy for your Mustang . . . what's left? A $1100 carbon fiber drive shaft, that's what.
Old Aug 29, 2005 | 04:55 PM
ZwerRacing's Avatar
That is the sexist thing I have ever seen. All kidding aside that is so cool and I agree if it was like $600 it would be great but $1100 is a little pricy. Though I could get the install for free.
Old Aug 29, 2005 | 04:58 PM
zwooky's Avatar
Will be a good mod after I'm supercharged and need to beef up the drivetrain. Not only adds strength, but adds power and lessens weight too.
Old Aug 29, 2005 | 05:16 PM
169stang's Avatar
I will be getting it installed this Thursday. Dyno pull before and after as well. The professional installation is due to the fact that installing a new rear yolk requires setting the pinion gear just like installing a new set of gears. The trick is to measure the current pinion depth, installing the new yolk and setting the pinion depth to where it was before. I don't want to deal with this for one, second, I want it done right. You really need the right tools for doing so and I currently don't have them.
I don't know about any corporate sponsors though.
I was talking to some different people about this and carbon fiber is very expensive as is, let alone a driveshaft. I initially looked into an aluminum one and they are roughly $600-700 for just that shaft. Then you have the yolks left, roughly $200. So you are looking anywhere from $800-$900 for aluminum. I'm not one for buying something due to being cheaper. I look more for quality and try not to have to do any redo's. I'm not saying that the aluminum one from JPC isn't quality. I know it is! Justin has one in his car now. If it wasn't great, he wouldn't be using it. I talked with a couple people and the concensus was that the carbon fiber would be a bit better. I'll spend a little extra for better. Until there are quite a few making them and the current companies can get their production costs down, it's going to be a bit more expensive. It's possible that if I lined up 5 or 10 takers, I could get the price down a bit. I really have no idea. I'd have to inquire. Maybe a poll or thread with a group buy. If a single person is interested, I'll make the calls.
Old Aug 29, 2005 | 07:40 PM
mikem's Avatar
Dave,Ime in. I want one.With that and the underdrive pullies installed plus a couple other home made mods I have up my sleeve............................Who Knows...........
Old Aug 29, 2005 | 07:41 PM
mikem's Avatar
