Car Hesitates.....wtf?!?!
Old May 29, 2005 | 06:46 AM
DaTT(1sK)'s Avatar
I was driving on the highway yesterday with the A/C on and I needed to pass someone, so I downshifted and tromped on it. The car didn't f*****g move. It bogged down, and then took off. At first I thought I may have hit the brake pedal too, but I downshifted again and it bogged down again. I was pissed the entire drive up north. I did it a few more times and it bogged.
I decided to try with the A/C off.......and it didn't bog. Then I turned the A/C back on and tried it again and it didn't bog. Anyone else experience this?
5-Speed if that makes a diff.
Old May 29, 2005 | 09:24 AM
StangFreak's Avatar
Have you reflashed the ECU with a performance tune??? If not the what your feeling is Ford's electronic nanny "Torque Management". It's designed to protect the drive line from any excessive abuse. A performance tune from Diablosport or SCT will fix the problem.
Old May 29, 2005 | 11:05 AM
DaTT(1sK)'s Avatar
The ECU has not been reflashed......but it may have to be. Are we sure about this? I shouldn't go in screamin at my dealer?
Old May 29, 2005 | 11:19 AM
wsmatau's Avatar
Unfortunately, StangFreak is 100% correct. The same thing happenned to me during my first week of ownership. If you try to go to WOT from idle the computer will interfere. The re-flash will cure what ails you!
Old May 29, 2005 | 11:35 AM
poldrv's Avatar
I had it happen last week while turning from the main highway to a secondary highway for a millisecond. Its the first and only time and yes the a/c was on.
Old May 29, 2005 | 12:13 PM
StangFreak's Avatar
Positive, check out some of the other links in the forum about this issue. My car is on order and one of the mods I will have waiting for it when it comes in is a Diablosport Preditor tuner to get rid of the drive by wire hesitation. Another plus is it gives you about 15 - 20 additional rwhp over stock. The other is SLP's Loud Mouth axle back exhaust so my neighbors can enjoy my new car too!!!
Old May 29, 2005 | 01:41 PM
DaTT(1sK)'s Avatar
I wasn't going from a idle....I was driving at about 120km/h and downshifted to 4th to get passed some dude. I hope it was your talking about. I will have to consider getting a flash done....soon!
Old May 29, 2005 | 01:47 PM
StangFreak's Avatar
Doesn't matter if its from idle or on a roll. If the ECU senses too high a load on the drive train it will back down the timing or restrict the throttle input to protect the drive line. If it makes you feel better take the car back to your dealer and let them look at it. If they say nothing is wrong then you know what you have read here is the answer. If they find some thing wrong then you saved your self the cash to buy the Preditor Tuner. Either way you can't loose!!!
Jim
jc46002003
Apr 15, 2016 03:00 PM
jim010
31
Sep 14, 2015 08:39 PM
f1-cobra
Aug 1, 2015 08:02 PM
roushcollection
Jul 28, 2015 02:08 PM
dohc97
Jul 19, 2015 07:29 PM
