can someone explain Mil eliminators??
Can someone explain how these work and where they go. Like the from two or back to sensors?? Going to have to pass emotions since I'm getting off road x pipe and long tubes
1 Post
MIL (Malfunction Indicator Light) eliminators only trick the computer to thinking the exhaust is functioning properly per the reading on that sensor. Emissions tests will result otherwise, and they'll be able to smell the difference.
Originally Posted by godspunk32
Correct, provided that your engine is producing out of range results for emissions-related compounds (NOX, Carbon Monoxide, etc).
JR
JR
1 Post
I depends. I mean, I have known people that have gone through emissions testing with gutted cats, and they've gotten away with it. Someone people I know have gutted their cats and gotten nailed for emissions. It really depends on how well your car is running and how tough the emissions test is.
Personally, I wouldn't do it. At some point in time, I'm going to remove my cats and put in a catless X pipe, but I'll retain the catted pipe for emissions testing, and swap every three years when I have to go.
JR
JR
1 Post
NJ doesn't even do a tailpipe test on newer cars, anymore. They just plug into your OBD-II port and see what's going on. Of course, if the sensors are turned off, they'll see that as a malfunction and fail you.
JR
1 Post
I failed my first test after getting my Brenspeed tune because of them turning off the rear cats. I honestly didn't even think of it. All I had to do was swap my stock intake back on, and retune, then drive 100 miles to get the computer set. Emissions passed, then out to door and back on with the CAI/tune.
JR
JR
JR
JR
1 Post
I was told / have read that they won't work on the 05+ Stangs, but I haven't tried them myself.
Do they do a visual inspection down there? I know they have mirrors up here to make sure you have the cats.
So it looks like several folks are hitting on parts of the issue. I responded in another thread. but may as well here too. I've been running LT for 4+ years in Texas. Gotta pass emission test every year. Yes, test is done via OBD port, not tailpipe sniffer (thankfully!). I installed MILs from the beginning so they would help with the O2 monitoring while driving. That part hasn't been an issue. However, I consistently have a CEL light for O2 sensors "rear O2 slow to respond" or something like that. It's been a while since I cleared those codes. P043 or something like that. Apparently it is due to them not warming up quick enough, since they are further from engine with headers. I think this is something that can be fixed in the tune. I just got back in contact with my original tuner, Chris at American Muscle. He is gonna hook me up with a new tune with all the latest tricks for passing OBD emission testing while having a modified 05 GT. We will see!
For those of you that have the sniffer test, I left my CAI and 91octane tune in place for my emissions test, which has to be done every year. I do have a catted x pipe, though I have a burned wire for the driver's rear 02 sensor and the engine light came on during the test.......BUT, because the car passed the EMISSION part of the test, I passed.....
Point is, if you go the sniffer route, you may not have to swap a bunch of stuff out if yer not spewing anything too noxious......
If you live in the Atlanta, GA area I know a guy that knows a guy who went to school with a guy who's mom knows this guys uncle.....well let's just say I know a guy who can help "pass" you with flying colors, even if you come in with no mufflers at all :-)
First of all, forget the MIL eliminators. They wont work on S197's. Ive tried, I can vouch personally.
In the state of Texas for vehicles 2001 and newer they will actually allow you to pass if only have 1 sensor that is in "not ready" state. I did actually pass my last inspection with the catalyst monitor in "not ready."
I had a tune that had the catalysts off so I flashed back before I got inspected. I apparently had not driven enough because I failed with catalyst and evap not ready. I drove around some more and went back the next day and passed since evap had cleared.
I'm going to leave it in the next time I go in. If the tune only eliminates catalyst, and evap and O2 are still good I should pass.
2/10/17 07:12 PM
Antigini-GT/CS
10/5/15 09:43 AM
