camber setting?
camber setting?
im lowering my 08 gt on wednesday with eibach sportlines and i wanted to know WILL I NEED CAMBER BOLTS? and what is the stock setting and what should it be at?
Factory camber tolerence is -.75 degrees (+/- .75 degrees) which is 0.0 to -1.5 degrees.
I'm betting that you'll require the camber bolts to bring it in specs.
yup, sportlines are the lowest of the eibachs, at about 2 inches, the prokits are abbout 1.3 - 1.5....I would def have the bolts with you( the ones you purchased somewhere other than the dealership) so they don't nail you by doubling price as you need them right away...most guys drive a couple hundred miles before the alignment anyway to allow the springs to settle before getting an alignment
