Camber/Caster/Toe
Old 3/17/11 | 12:04 PM
Bennyandthejets's Avatar
Camber/Caster/Toe
Had an auto care place align my car after I installed frpp suspension. Do these numbers seem reasonable or were they sloppy? (all numbers are front)
Front
L-1.4, -0.8R
Caster (bolts installed)
L6.7, 7.4R
Toe
L .1, .05R
They're all in the "green" but I'm most skeptical of the camber numbers. One side is almost twice the other.
Old 3/17/11 | 02:33 PM
Ministang's Avatar
If it were my car I'd take it back and tell them to even up the camber numbers. Hard to tell though if it was the tech being sloppy, or if their equipment isn't terribly good and isn't very accurate.
Old 3/17/11 | 03:25 PM
slidejob's Avatar
See if they will set it up with you sitting in the car.
Try to get more camber in the RF.
I like lots of + caster, that # looks good.
Toe looks OK for street.
Old 3/17/11 | 05:37 PM
Thanks for the advice. I was actually thinking less camber for tire wear purposes. In a perfect world I'd like to see the camber at ~1 degree. If the caster is ok then I probably won't bother with it. I hadn't even thought about the difference my weight makes. I wonder if they did.
Old 3/17/11 | 05:55 PM
11SHELBYGT500's Avatar
Or if you have free weights, that will also work. Put them behind you seat.
Old 3/17/11 | 06:12 PM
did the alignment shop install the camber bolts?
Old 3/18/11 | 01:14 PM
Yes they did, if you mean the caster bolts.
Old 3/18/11 | 06:02 PM
well tell those suckers to stand your wheels up more. I didn't even take mine back last time I just did it myself. Buy a tread depth gauge!
