Cam swap help
Cam swap help
I'm going to be helping a friend of mine do a cam swap on his 07 GT. I've done several LS1s and SBCs but never a modular. From what I've read the only confusion I have is with the roller followers. Which basically looks to me like a rocker arm. On the how to I've been reading it says I need the valve spring compressor to get the roller follower out and it says as the valve spring is being compressed make sure the valve is going down with it. Well if the valve goes down doesn't that mean its going into the cylinder? or is it that the piston is up on those cylinders holding it up and giving just enough space for the follower to become free?
Also, saw this for sale today. Might help.
https://themustangsource.com/f722/we...3/#post6461914
Good luck!
It is a safety thing to keep the retainers from popping out. If you have the right shoe on the spring compressor they can't come out. One is for spring removal and the other is just to compress them.
