Cam Phaser deletion?????
Old Apr 25, 2024 | 05:00 PM
msinc's Avatar
Why do folks "delete" the cam phasers in Mustang GT 4.6lt 3 valved engines???? Thanks in advance for any info!!!!!
Old Apr 25, 2024 | 07:45 PM
05stangkc's Avatar
Phaser limiters or even lockouts are required if you install performance cams that have a high enough valve lift/opening duration that would otherwise cause piston to valve contact. Full VCT functionality ensures that the torque band is as wide as possible with optimum driveability. Once you restrict or eliminate VCT function, those characteristics are compromised. Usually it's the idle quality, low rpm torque, and low rpm driveability that suffer.
Also on a Side Note If You Need New Phasers Use Genuine Ford as The Aftermarket ones are Junk They Say!
Although on a 5.4L Good Info on this Vid.
KC
Old Apr 26, 2024 | 07:42 AM
msinc's Avatar
KC, thank you sir!!!!!!!! Now I understand completely!!!!! M
ponyexpress82
Jul 23, 2012 06:41 PM
Brawlin' Boss
Jan 17, 2012 12:01 PM
coffeeGTCS
2007-2009 Mustang GT/CS
Mar 14, 2011 02:34 PM
Slims00ls1z28
Nov 26, 2009 02:30 PM
luvthe440Aroush
1994-2004 V-8
Nov 30, 2005 09:26 PM
