CAI...
The 3 best Short Ram Intakes are the JLT, C&L and the WMS front mounted unit IMO. The WMS greatly interupts the underhood look and you have to relocate the 2 reservoirs that mount to the radiator support. All other Intakes use the same sideway path but the JLT shows the lowest intake temperatures due to its plastic design.
Cant go wrong with the JLT.
-Dan
-Dan
The reason why the Anderson Ford Motorsport kit is expensive is because, it uses a ProM 80mm. mass air sensor that is calibrated to work with thier (larger intake tube), which requires no computer re-flash.. with all other CAI's that use the stock mass air sensor, a re-flash is a must to prevent improper a/f ratio problems, with the exception of the k&n, However thier intake tube is actually smaller in some areas then that of the stock intake..
http://mustang50magazine.com/techarticles/...old_air_intake/
Here is there comparisons of most cai's available. Is one of the lower scores for this cai, and oh my god the price, are you kidding. good luck
"Since the dawn of the 5.0 Mustang, Rick Anderson of Anderson Ford Motorsport has been a student of how a Mustang gets air into its engine. His Power Pipe is a staple of the Mustang aftermarket, so it was no surprise his '05 version has so much to offer. It features a massive 80mm Professional Mass Air Systems mass air meter that can be calibrated to work with 19-, 24-, or 30-lb/hr injectors with no flash needed. Beyond the impressive hardware, not having to worry about a third party "correcting" the computer is a huge bonus and justifies the initial price.
"Through design, the Power Pipe delivers a larger volume of cooler air to the engine," Rick Anderson states on his Web site. "By doing so, our '05 Mustang has produced up to 16 additional rear-wheel horsepower from simply installing the Power Pipe with mass air meter with no additional tuning needed."
In a plug-and-play society, this is the king of the bolt-on-and-forget-it '05 CAI kits. We especially like the versatility of this unit and the obvious built-in oversizing for when things like heads/cams/intake packages become available for your favorite Mustang.
Keep in mind: Our photographs show the prototype for this setup, so the paint, chrome, and welding isn't perfect like the production piece you can buy now. Even though it didn't need a tune, our judges were hesitant about the value of the AFM piece. Still, they thought it was well built with a high level of Expected Durability. This is a cold-air system that's built to grow with your combination. Should you add a blower or turbo, you can still use the 80mm Professional Mass Air Systems meter.
By the Numbers
AFM Power Pipe
Price: $569 (PN AF-0115C)
Peak Horsepower: 280 (19hp gain)/(287.6 hp with SCT tune)
Peak Torque: 296 lb-ft (14-lb-ft gain)/(302.2 lb-ft with SCT tune)
Subjective Evaluation
Ease of Installation: 27
Value: 23
Appearance: 34
Overall Quality: 35
Expected Durability: 39
Total: 158"
By the Numbers
AFM Power Pipe
Value: 23
Appearance: 34
Overall Quality: 35
Total: 158"
