C&L w/ Predator tune
I just called C&L and was told the cai and Predator combo will be ready for the 06's in about a week. They said they are finishing up loading the new 06 computer codes. They also said in about another three weeks they are going to be offering a new cai w/ a predator tune with a larger plastic inlet pipe. It will be about $100.00 cheaper than the current cast inlet pipe. Just an FYI to anyone considering this mod.
We already have the 06 files for the C&L and the GT's so if you don't want to wait for the Diablo tuner and C&L you can go with an X-calibrator. I've already sold two C&L/x-2 kits to 06' owners.
Thanks, Doug
Thanks, Doug
Originally posted by Dubai@September 25, 2005, 5:08 PM
emm what is the diffrent between SCT X-Cal 2 and diablo what can sct xcal 2 do that diablo doesnt and what does diablo do that scat xcal 2 doesnt??
Yeah what he said. What is the difference???????
DIABLOSPORT PREDATOR TUNER
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
Global Timing adder -6 degrees /+4 degrees
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
RPM Shift Points, adjustable via MPH
Cooling Fan ON/OFF Temperatures
MAF curve adjustment
All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
SCT X-CALIBRATOR 2 TUNER
FUEL ADJUSTMENT
Wide Open Throttle:
6% Leaner to 14% Richer
SPARK ADJUSTMENT
Global Spark: -5 to +5 degrees
RPM Adjustment Spark:
0 - 2000RPM: -14 to +4 degrees
2000 - 4000RPM: -8 to +4 degrees
4000 - 8000RPM: -8 to +4 degrees
TROUBLE CODES
Diagnose Check Engine Lights & Clear Trouble Codes
AXLE RATIO SELECTION
2.73 to 5.14 Ratios
MAF SELECTION
80mm to 90mm Lightning SCT Big Air BA-2400 & BA-2800 MAF Meters
TIRE SIZE SELECTION
205/65/15 to 315/35/19
FUEL INJECTOR SELECTION
19lb to 60lb Fuel Injectors
OTHER SELECTIONS
Idle RPM: -300 to +300RPM
Cooling Fan: On / Off Temp
Traction Control: On / Off
Two Step: On / Off & RPM
SHIFT ADJUSTMENT
Automatic Transmission Shift Schedule:
WOT 1st - 2nd: -3 to +7mph
WOT 2nd - 3rd: -4 to +8mph
WOT 3rd - 4th: -5 to +10mph
WOT 4th - 5th: -5 to +10mph
Hope this helps!
The KEY is the availability of SAFE and QUALITY Tunes from a QUALIFIED Tuner along with after the sale Support and Customer Service. Here again I think SCT is the better choice and Doug at BamaChips can't be beat in my opinion, his tunes are Awesome and his customer service is Excellent. Do a search during the past year on this forum on BamaChips and read the post. You won't find not 1 member that is unhappy, they will all have positive comments.
Guest
Posts: n/a
Originally posted by 24FAN@September 29, 2005, 12:00 PM
Can someone tell me the difference in the tuner disabling the traction control as opposed to the traction control button on the console instrument cluster.
The SCT X-Cal 2 also lets you control the shift firmness in the auto trannys.
Thanks, Doug
Thanks, Doug
Originally posted by Mongoose@December 5, 2005, 1:40 PM
I will sell you my Predator 300 shipped.
Originally posted by Dubai@September 29, 2005, 4:23 PM
thanks alot it really helped.
1 more thing.. which flash comp can take off the engine light of the 02 sens??
Originally posted by TexaStang@December 5, 2005, 11:21 PM
Predator is a waste of time
The new C&L intake? Are you guys referring to the "race" intake system with 95mm plastic inlet tube that costs about $100 less? From what I've read, this system makes less power/torque than the "street" system.
