C&L w/ Predator tune
Old Sep 23, 2005 | 02:59 PM
OKLACOP's Avatar
I just called C&L and was told the cai and Predator combo will be ready for the 06's in about a week. They said they are finishing up loading the new 06 computer codes. They also said in about another three weeks they are going to be offering a new cai w/ a predator tune with a larger plastic inlet pipe. It will be about $100.00 cheaper than the current cast inlet pipe. Just an FYI to anyone considering this mod.
Old Sep 24, 2005 | 08:31 AM
Doug@C&L's Avatar
We already have the 06 files for the C&L and the GT's so if you don't want to wait for the Diablo tuner and C&L you can go with an X-calibrator. I've already sold two C&L/x-2 kits to 06' owners.
Thanks, Doug
Old Sep 25, 2005 | 07:06 AM
traffic142's Avatar
doug how much for the new tune/intake set up??
Old Sep 25, 2005 | 12:26 PM
doc0075579's Avatar
I just purchased the C&L and tune for the 06 from Doug, it's like night and day in how the vehicle responds. More power and better throttle response.
Old Sep 25, 2005 | 05:05 PM
Dubai's Avatar
emm what is the diffrent between SCT X-Cal 2 and diablo what can sct xcal 2 do that diablo doesnt and what does diablo do that scat xcal 2 doesnt??
Old Sep 27, 2005 | 04:03 PM
OKLACOP's Avatar
Yeah what he said. What is the difference???????
Old Sep 28, 2005 | 04:25 AM
KWMJ-KTP's Avatar
Here is what each manufactuer has on their site. I don't believe the list on the SCT is a complete list of it's functionality, because I know it can remove or adjust the rev limiter and same on the top speed governor, but those aren't listed.
DIABLOSPORT PREDATOR TUNER
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
Global Timing adder -6 degrees /+4 degrees
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
RPM Shift Points, adjustable via MPH
Cooling Fan ON/OFF Temperatures
MAF curve adjustment
All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
SCT X-CALIBRATOR 2 TUNER
FUEL ADJUSTMENT
Wide Open Throttle:
6% Leaner to 14% Richer
SPARK ADJUSTMENT
Global Spark: -5 to +5 degrees
RPM Adjustment Spark:
0 - 2000RPM: -14 to +4 degrees
2000 - 4000RPM: -8 to +4 degrees
4000 - 8000RPM: -8 to +4 degrees
TROUBLE CODES
Diagnose Check Engine Lights & Clear Trouble Codes
AXLE RATIO SELECTION
2.73 to 5.14 Ratios
MAF SELECTION
80mm to 90mm Lightning SCT Big Air BA-2400 & BA-2800 MAF Meters
TIRE SIZE SELECTION
205/65/15 to 315/35/19
FUEL INJECTOR SELECTION
19lb to 60lb Fuel Injectors
OTHER SELECTIONS
Idle RPM: -300 to +300RPM
Cooling Fan: On / Off Temp
Traction Control: On / Off
Two Step: On / Off & RPM
SHIFT ADJUSTMENT
Automatic Transmission Shift Schedule:
WOT 1st - 2nd: -3 to +7mph
WOT 2nd - 3rd: -4 to +8mph
WOT 3rd - 4th: -5 to +10mph
WOT 4th - 5th: -5 to +10mph
Hope this helps!
Old Sep 28, 2005 | 05:17 AM
mlcrisis's Avatar
I don't know that I would worry about the differences in the two tuning devices. They are both pretty close in doing the same things, however, I think SCT is the better choice.
The KEY is the availability of SAFE and QUALITY Tunes from a QUALIFIED Tuner along with after the sale Support and Customer Service. Here again I think SCT is the better choice and Doug at BamaChips can't be beat in my opinion, his tunes are Awesome and his customer service is Excellent. Do a search during the past year on this forum on BamaChips and read the post. You won't find not 1 member that is unhappy, they will all have positive comments.
Old Sep 29, 2005 | 11:57 AM
24FAN's Avatar
Can someone tell me the difference in the tuner disabling the traction control as opposed to the traction control button on the console instrument cluster.
Old Sep 29, 2005 | 04:20 PM
Dubai's Avatar
thanks alot it really helped.
1 more thing.. which flash comp can take off the engine light of the 02 sens??
Old Dec 5, 2005 | 11:24 AM
2006GT's Avatar
Thanks, Doug
I looked on your website and could not find your C&L SCT package. How much?
Old Dec 5, 2005 | 11:37 AM
Mongoose's Avatar
I will sell you my Predator 300 shipped.
Old Dec 5, 2005 | 11:55 AM
2006GT's Avatar
Sent ya a PM man...
Old Dec 5, 2005 | 04:01 PM
nicksolheim's Avatar
Both
Old Dec 5, 2005 | 08:11 PM
05-1947's Avatar
The difference is that you have many people who praise guys like Doug and Brent for their tuning abilities with the xcal 2 and very little on the predator.
Old Dec 5, 2005 | 08:18 PM
TexaStang's Avatar
Predator is a waste of time, xcal2 is king just because of the tuners for them, not to mention features.
Old Dec 6, 2005 | 07:28 AM
ski's Avatar
ski
Just curious. Are you speaking from personal experience?
Old Dec 6, 2005 | 09:46 AM
BLT2RUN's Avatar
The new C&L intake? Are you guys referring to the "race" intake system with 95mm plastic inlet tube that costs about $100 less? From what I've read, this system makes less power/torque than the "street" system.
wallace
Mar 29, 2016 10:09 AM
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
