Bump Steer with Wider Tires?
Old Sep 7, 2008 | 09:53 PM
jedikd's Avatar
I recently installed a set of Steeda Ultra-lite springs, and drove for about a week with this on stock rims no problems, ride was not noticeably worse than stock. This weekend I installed 18x9 wheels with 275/40/R18 tires all the way around, and the main thing I'm noticing is a tendency for what I could only describe as "bump steer" pretty heavily. Is this a side effect that everyone experiences going from 235 to 275 wide wheels (front/rear)? I have not had the car aligned since doing the spring install, and plan to this weekend, could that be the culprit?
So far the handling seems great with the new wheels/springs, but the bump steer makes the car a little more difficult to control it seems.
Old Sep 8, 2008 | 10:15 AM
70MACH1OWNER's Avatar
I run the same size wheels and tires in the summer months and switch back to the stockers in the winter months and I feel the same thing you are talking about. I am not sure if bump steer is the correct term to use but I notice that they will track in a crack or seam in the pavement more the the stockers do also.
Old Sep 8, 2008 | 10:20 AM
jedikd's Avatar
Yup, exactly how it feels to me. Car handles great with 275s on all 4 corners, just have to be careful on rough roads.
Old Sep 8, 2008 | 12:42 PM
Cobrakev's Avatar
It's not bump steer, it is the wide tires you just put on. More tire on the road, will track in the uneven/rough road.
Old Sep 8, 2008 | 03:19 PM
colbymh's Avatar
The bump steer kit helps out a TON tho. I can hit a nice bump with hands barely touching the wheel and my car wont fly off the road anymore. Before that I would do the same and almost end up in a field. It truly is night and day difference. 255/f, 285/r
Old Sep 8, 2008 | 03:46 PM
Good info Colby...I will investigate the Steeda bump steer kit!!!
Old Sep 8, 2008 | 03:48 PM
tom281's Avatar
Yeah, do that Scott........ then tell me what you think and maybe I'll do it then LOL.
Old Sep 8, 2008 | 04:37 PM
Do you have the same issue with the wider meats???
Old Sep 8, 2008 | 06:17 PM
colbymh's Avatar
one more thing to add. After they put the bump steer kit, they needed to add a camber kit because it was off quite a bit. Only like $20 bucks for that tho.
Old Sep 8, 2008 | 06:22 PM
Got a link to the camber kit? Who did you buy it from?
Old Sep 8, 2008 | 06:41 PM
colbymh's Avatar
They had them in stock where I went, but here is a link.
http://www.streetsideauto.com/produc...YMM&Reset=True
Old Sep 9, 2008 | 06:13 AM
bump steer kit helped me I also used camber bolts to bring it all together.
an article I found on bump steer
http://bakerprecision.com/longacr17a.htm
and another one
http://www.naxja.org/html/techarticl...psteertech.htm
Old Sep 9, 2008 | 07:42 AM
blkstang06's Avatar
....:gay:
Old Sep 9, 2008 | 08:06 AM
OneCoolGT
Dec 10, 2015 07:55 PM
y5e06
Sep 21, 2015 08:05 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 8, 2015 10:45 AM
