Broke into 12,s
Originally posted by mikem@August 17, 2005, 7:08 PM
[b]Well tonight was the night.
60Ft 1.73 No suspension mods except removal of front swaybar.
1/8 8.20
mph 84.07
1/4 mile 12.86
mph 105.86
CAI/4.10 gears/MAK offroad pipe/steeda Predator Tune and MT Streets.
Just trying to show you dont need much,just the things that realy matter.![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
1/8 8.20
mph 84.07
1/4 mile 12.86
mph 105.86
We couldn't even approach those times here in Phoenix...
![Drool](https://themustangsource.com/forums/images/smilies/drool.gif)
Originally posted by cambostang@August 18, 2005, 5:48 PM
what size m/t's are you running and on what rims? stock rims? where did you buy them?
-Dan
Running stock Bullits with MT ET Street 26-11.5- 17LT(Biasply) with 13PSI.Also I put 50PSI in front tires.Launch between 4500 and 5000.Shift at 6200.The 4.10,s realy picked up my sixty foot.
Guest
Posts: n/a
Originally posted by Weedo@August 18, 2005, 7:55 PM
Where do you live?
We couldn't even approach those times here in Phoenix...![Drool](https://themustangsource.com/forums/images/smilies/drool.gif)
Where do you live?
Originally posted by Weedo@August 18, 2005, 6:55 PM
Where do you live?
Where do you live?
Ran again tonight.track was treated because of FUN FORD WEEKEND.I was able to launch at a solid 5000.I ran 12.77@106.42 with a 1.71 60 ft
I realy need to get line locks installed.Started only spinning one tire in the burnout.
![Banana](https://themustangsource.com/forums/images/smilies/banana.gif)
I planned on going this sat and sunday But, I am burntout and all the heavy hitters were dialing there cars in tonight.So I got to see them run.I am up to 7 passes between Wed and tonight and i think i am loosing the rearend clutches do to all these burnouts without linelock.Must installl them before i return.
Guest
Posts: n/a
Awesome times Mike!!! I busted the driveshaft bearing that is between both driveshafts tonight. There is a crossover or chassis tie-in just below that bearing. With every single shift, the driveshaft was slamming that crossover piece. I pulled both wheels off the ground tonight. I didn't get any pics though. I'll be sure to have a camera next time. The front left came up about 14" and the right about 4". SOOO much twist in the car. It pulled me out of the groove and almost into the center line. Honestly, it freaked me out. This was my first run on true slicks and front runner's. I shifted into 2nd early, then my CEL returned and was running rich the remainder of the way down the track. Still ran a 13.1 @ 103. I don't mean to hijack your thread. I just didn't feel this info was worthy of another thread. I admire your times with your mods!
Thanks bud,My thread is your thread.I was wondering how the driveshaft setup on our cars would hold up.Dont realy like the two piece idea. :scratch: Did you way your car with the Bogarts on?
No, I didn't even think about weighing the car. I did weigh the wheels and tires. Overall, it dropped 56 lbs. off the car. 38lbs of it was in off the front. The 28"x10.5" tires are a bit heavy, but still lighter than stock. I'm going to call a buddy that works with BMR tomorrow to see what the time frame is on single piece driveshaft. That bearing comes as part of the front driveshaft according to the service manual. This sucks!
Im starting into the drag racing craze but I dont want to start breaking things. I guess line locks should be next on my list even though I dont spin the tires that high in the rpm when in 2nd. I suppose I could spin the tires faster when the locks are installed...peace of mind.
-Dan
-Dan
The line locks will really reduce any stress on the rear brakes, differential and the clutch. I drop the clutch in 3rd at 5000 rpm's for burnouts. It's fun too.
They will be ordered monday.
Also,I argued with Tech Inspector about the driveshaft loop.He said I need one.i said you mean i need two In that case.If you look at our driveshaft setup there is no way in heck either shaft could fall to the ground.Exhaust and center bearing would not alow it.Also I watched Mith Busters on TV and they could barely get a car to cataulpolt even landing front of shaft into hole:geek:Not going to happen on a smooth surface like the track.
Due to my center bearing going bad, I was under the car this morning looking at what'll need to be done to change the driveshaft. I was looking to see if I could do it without removing the exhaust. I couldn't get the crossmember/tie-in out. The x-pipe would have to be removed. I'm going to see if I can slide the driveshaft in from the back of the x-pipe. There's no way the driveshaft could hit the pavement with that crossmember/tie-in or the exhaust. FRPP makes a driveshaft loop or a double one at that. WASTE! IF...I go to a single driveshaft, I will put in a loop. But I think I'll put in an OEM driveshaft and put in another swaybar and see how it holds up. I've found a carbon fiber single driveshaft, but they want $1200 for it. I just can't justify it.
