Brenspeed b302 stage 2 stroker kit
Old Jan 17, 2012 | 07:30 AM
mptant913's Avatar
Anyone running this set up and can help me out with the costs and experience with it?
Thanks guys
Old Jan 18, 2012 | 03:45 PM
brenspeed can?? Just being a smartazz. Have you been to their website?
Old Jan 18, 2012 | 09:43 PM
mptant913's Avatar
Yea I spoke to them and got some good info.. found a place close by that will stroke the block so I can save money by putting the kit in ..just was checking to see if someone here had it already done and how they like it
Old Jan 19, 2012 | 03:08 PM
you don't gain any hp from doing this correct? It just makes it stronger for when you add a sc or turbo?
Old Jan 19, 2012 | 03:31 PM
slidejob's Avatar
Yes, they claim you gain 30-40hp by increasing your displacement by .4 liters. I am also considering a stroker.
Here is a nice build.
http://www.s197forum.com/forum/showthread.php?t=75982
Old Jan 20, 2012 | 06:56 AM
mptant913's Avatar
Its basically the parnelli jones engine which is rated at 400hp at the flywheel.. so you def get a hp increase from stock and with bolt ons I am sure you can see impressive numbers for a N/A stang
Thanks for the link
Old Jan 20, 2012 | 07:50 AM
Pete07GT's Avatar
Thanks for the link
400HP? Show me a Dyno Sheer running anything other than race gas and I'll believe it. 100HP gain in a naturally aspirated engine with only a stroker kit? Impressive if proven but for $2700+ I can procure a turbo on 8psi putting 420rwhp down.
Old Jan 20, 2012 | 08:23 AM
mptant913's Avatar
I guess look up the dyno sheet for a parnelli jones mustang because that's basically what the engine is.. close too 400 hp at the flywheel sounds right to me... your also making your engine stronger for a sc... dude procure me a turbo ir something and ill be more then happy to buy it but from what I seen your not getting a reliable supercharcher or turbo for under 4k... plus this option is best for because with my bolt ons and all I need is to get a block machined and I put this kit in I should make close to 400 if not more rwhp and if not im deft dipping into low 11's ya know .. plus would like to slap that 5.0l badge on the car : )..
Old Jan 20, 2012 | 04:23 PM
I kind of remember talking to the folks at brenspeep and them telling me that you didn't really gain much hp from a stroker kit.
Old Jan 20, 2012 | 04:29 PM
yep here we go. https://themustangsource.com/f637/ge...y-sale-500026/
Old Jan 20, 2012 | 04:46 PM
mptant913's Avatar
That's sucks man..... I mean I doesn't make sense this is a response I got from Saleen " Horse power will depend on what mods you choose to add. The PJ cars which were naturally aspirated with just the stroker kit, generated about 400 HP at the flywheel. Later cars such as the H302SC and S302E were 580HP and 620HP, but this was with a supercharger (with lower compression pistons for that application) along with head work (no headers because emissions would need to be met).
Even things like cost can vary depending on the shop used and the specific work you want done.
I would contact Brenspeed to get their information on their kit and what they recommend. Although their kit is based on ours, they would still be the best source of"
I mean I dunno what i would get with bolt ons.. and superchargers are just really expensive ... im also looking for wrecked 2011-2012 mustangs to do a swap but even those totaled are a lot of money right now
Old Jan 20, 2012 | 04:57 PM
mptant913's Avatar
http://farm4.static.flickr.com/3510/...53318657a9.jpg
Here's a dyno sheet for the pj ... 335 rwhp that sounds right to me... that with my bolt ons say I get 10hp from each bolt on I have I should be pushing close to or well over 400 rwhp with a really good custom tune
Old Jan 20, 2012 | 05:31 PM
I think for the most part you do not need this unless you plan on going over 500 hp
Old Jan 20, 2012 | 05:36 PM
mustangray's Avatar
A stock PJ 302 was more then just a strocker kit it also had ported and polished heads different cams with 10.5 to 1 compression and after a good custom tune mine was running about 425 at the motor
Old Jan 20, 2012 | 06:15 PM
mptant913's Avatar
Lol I guess an engine swap or supercharger is the best way to go
Old Jan 20, 2012 | 06:32 PM
I have to agree or a turbo.... just because its easier to say turbo over supercharger
Old Jan 29, 2012 | 04:51 PM
HG6283's Avatar
No real gains from a little displacement bump.
Definitely a supercharger FTW.
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
blackhawkkid308
Sep 30, 2015 04:04 PM
RoushRS3
Sep 29, 2015 08:03 PM
