Brembo Take Offs
Old Nov 4, 2012 | 08:55 PM
06blackvertstang's Avatar
Brembo Take Offs
Does anyone have any experiences with switching to brembo take offs? Either from gt500s or other new ones I guess.
What would all would you need? Prices? Any info? Trying to get informed. Thanks
Old Nov 14, 2012 | 11:19 AM
rony1976's Avatar
Take the old, put the new in. Probably recommended to bleed your system as well.
Simple tools, not much science. I see Brembos on ebay with discs and lines between $700-$1000.
Old Nov 14, 2012 | 03:56 PM
That's also what I've seen. It's a much much cheaper alternative to an actual big brake kit, but I didn't know if it was a good route to take
Old Nov 14, 2012 | 04:05 PM
Worked for me. Got them from a member here. He took them off his GT500 after a few hundred miles. I got front and back calipers, rotors, and pads. I already had Goodridge brake lines and everything just bolted right up.
I highly recommend it if you know they are like new. Also very, very easy to do! I think my wife could do it if I stood there and told her the steps.
Old Nov 14, 2012 | 04:35 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
And buy wheels to clear them.
Old Nov 14, 2012 | 11:36 PM
That's also a point to consider. Well thanks fellas. Is it not necessary to bleed the lines then Gary?
Old Nov 14, 2012 | 11:43 PM
It is absolutely necessary.
I went ahead and changed the fluid in the system while I was in there. Bought a pressurized brake bleeder that attached to the master cylinder at the cap. But I've used it on a few of my vehicles so that worked out for me.
Old Nov 15, 2012 | 07:04 AM
69Mach1-409's Avatar
You'll have zero brakes if you do not bleed the fronts.
Old Nov 15, 2012 | 08:03 AM
Gotcha. I had a feeling that might be a dumb question. Just trying to learn all I can
Old Nov 15, 2012 | 09:04 AM
Doogie's Avatar
I am running a set of take-offs as well and got lucky with the price as I only paid $520 shipped from a guy on TS who had his GT500 upgraded to a SS. Another easy way to complete the bleeding process is using speed bleeders as they made the process very simple.
lowblustang00
Sep 5, 2015 12:18 PM
lowblustang00
Aug 13, 2015 05:00 PM
JonsMustang
Aug 10, 2015 05:03 PM
lowblustang00
Aug 8, 2015 04:48 PM
Coyote5-0
Jul 17, 2015 03:47 PM
