Which brace should I get?
Hey guys,
Sorry for the newb question (yes I'm full of them
) but I'm trying to decide which brace I should get to help tighten up the front end (after the strut tower replacement) of my mustang. I was considering the Steeda G-trac brace, the CHE 4 point K member brace or simply the factory brace (that the 08's and verts have). I'm not so concerned about price difference so long as it's reflected in its quality and usefulness. Also since I'm new at this stuff, I need to be sure these are all just simple bolt on parts and that it won't throw anything out of wack where I'll have to make adjustments, such as front end alignment, etc., after installing it.
thanks,
Mark
) but I'm trying to decide which brace I should get to help tighten up the front end (after the strut tower replacement) of my mustang. I was considering the Steeda G-trac brace, the CHE 4 point K member brace or simply the factory brace (that the 08's and verts have). I'm not so concerned about price difference so long as it's reflected in its quality and usefulness. Also since I'm new at this stuff, I need to be sure these are all just simple bolt on parts and that it won't throw anything out of wack where I'll have to make adjustments, such as front end alignment, etc., after installing it.thanks,
Mark
The CHE looks well-engineered but I am more concerned about extra weight on the front end which would ruin the weight distribution of the car. The Mustang's weight distribution is almost balanced and is considerably better than the average car on the road.
However, I decided to go with the OEM A-Arm brace that was used on all convertibles, the GT500, and all 08-up Mustangs. It was inexpensive and passed extensive factory testing (FEA, NVH, etc...) to be approved for use on the entire platform.
The G-trac brace relies on the 2 bolts for support. Unfortunately, the included bolts have threads on most of the shank, so you are relying on the weakest part of the bolt since the G-trac bar is unlikely to flex.
I haven't heard anything about substantial improvements going with a CHE or G-trac over the OEM A-Arm brace. I bought my OEM A-Arm brace from John Bleakley Ford:
M-5025-A
http://209.60.227.212/frparts.asp
M-5025-A
I've got the CHE brace on mine and I went with that one since it's the only one out there (that I know of) that you can use the torque limiter bars with. The torque limiters really tightened up the shifter...I have a Hurst and I can really slam that thing into third at high rpms with total confidence.
I did notice that the front end dove into corners a little better after installing it. I also have a strut tower brace up top, but didn't feel anything when that was put on, but that brace on the bottom really works. I would think that most any brand of brace will give a tighter front end though.
The CHE is like a hybrid g-trac and k-member brace. If you're attempting to tighten up the crossmember, the OEM bar appears to do the most work since it is located at the rear most section of the brace.
I see you have the MGW shifter in your future mods.... With the MGW shifter you won't need the CHE with torque limiters, because you won't have any binding problems.
I have the BMR A-Arm Support, it is only $59.95 and the quality is very good. The CHE (without limiters) or G-Trac will also be a good choice. It's kinda a matter of personal preference.
Bobby M.
Bobby M.
That's not to say that the MGW isn't a good shifter, it just has the same remote mount limitations as all the rest.
Sure you can...the binding isn't because of any particular shifter, it's a result of the shifter design being remote mounted. The engine/tranny twists under torque twisting the shifter arm itself and it can bind at it's pivot points...no shifter brand is going to stop that. You either need torque limiter bars or stiffer motor mounts or both to stop it entirely.
That's why I don't understand the rationale of people not wanting to pay $295 for the MGW, yet they will pay $279 for a Pro 5.0, Steeda or now the Hurst Billet and then go and pay $150 for a CHE with torque limiters to fix the binding problem.
It's a matter of preference, but I just don't get the math... when they say the MGW is to expensive... MGW has the best of everything, customer service, build quality, operation and all the adjustability you could want.
Bobby M.
Thanks again for everyones input.
I ended up pulling the trigger and puchased a CHE brace with torque limiters last night. If this works as good as what I've been reading on this and other forums, I may not even need the MGW shifter now
....we'll have to see.
Not to start another MGW war here, but all shifters are not made the same. The MGW is designed so that the when the engine/tranny twist the front support arm can pivot with the movement and doesn't bind the shifting mechanism... therefore no missed shifts because of binding.
Bobby M.
Bobby M.
Just my 2 cents
Jed
Bobby M.
Bobby M.
Feb 10, 2017 07:12 PM
Sep 16, 2015 06:44 PM
Sep 1, 2015 01:19 PM
