Boss/GT500 rear diff cover install
Old Sep 1, 2013 | 09:17 AM
Jaden's Avatar
For those that are interested in doing this mod, here's a photo of the parts. I moved the axle vent from the axle tube to the cover and capped off the axle tube hole. This solved my problem of getting gear lube all over the right hand axle tube and wheel. Cost me about $85 in parts.
Attached Thumbnails Boss/GT500 rear diff cover install-img_20130512_131407_819.jpg
Old Sep 1, 2013 | 02:49 PM
SoFlaBoss's Avatar
Dan, Perfect timing! Please let me know where you purchased that plug. I have all but that part to do the same modifications to my pony. Thanks so much.
Old Sep 1, 2013 | 02:52 PM
Jaden's Avatar
Summit racing: http://www.summitracing.com/parts/fra-481404-bl
Old Sep 1, 2013 | 03:09 PM
SoFlaBoss's Avatar
Fantastic! Thanks Dan!
Old Jan 19, 2023 | 12:51 PM
Bcomf38's Avatar
In attempts to revive this a decade later… Did you find any way to plug the other two oil cooler ports at the bottom by the drain plug? I can’t find a fit to them. How can I tell if they have been drilled?
Old Jan 19, 2023 | 01:40 PM
05stangkc's Avatar
@Bcomf38
I think the Specs you are Looking For are Listed Here!
If you Get a Cover From a Ford dealer it's a Bare Cover. The Ford Racing Version Looks to Come With Goodies!
https://performanceparts.ford.com/part/M-4033-KA
FORD RACING M-4033-KA
https://www.fordpartsgiant.com/parts...&filter=(39676)
OEM SERVICE {Bare COVER DR3Z-4033-B
https://www.fordpartsgiant.com/parts...9676)&pnc=4346
OEM AXLE COVER BOLTS {Spec Reference. Have to Buy 12 Because Pkg of 4}
https://www.fordpartsgiant.com/parts...rear_axle,,HM1
REPLACEMENT Cover Plugs Magnetic.
Although on a Ranger Some of the Install Info Can Be Gleened From this Link.
http://www.fordrangerforum.com/how-t...-8-8-rear.html
Scroll Down
KC
UNDRILLED COVER
Old Jan 19, 2023 | 02:08 PM
Bert's Avatar
the finned diff cover that I installed on my car did not have any "oil cooler ports at the bottom near the drain plug" so I think the simple solution is to buy the one that does not have those, like KC suggested above
pretty sure I got mine from tascaparts.com and it cost about $80 (with no bolts) if I remember correctly
Old Jan 19, 2023 | 02:14 PM
05stangkc's Avatar
Price Has Increased Dramatically These Days!
KC
Old Feb 10, 2023 | 02:14 PM
Bcomf38's Avatar
I realize I have purchased the correct cover. Curious what those ARP bolts are, I’ve heard stock ones don’t fit with this cover. Send me a link if and when you can
Old Feb 10, 2023 | 02:18 PM
05stangkc's Avatar
@Bcomf38
These are the Ones Shown in Post 1
https://www.summitracing.com/search/...651-1250%20arp
These are OEM Ford As Shown in Post 6
Port Plug if You Need iT! As Shown in Post 1
https://www.summitracing.com/search?...yword=481404bl
Enjoy
Get Twelve!
KC
Old Feb 10, 2023 | 02:19 PM
Bert's Avatar
I don't know the bolt size/thread off the top of my head, but you need the same thread as the stock bolts but about 1/4-3/8" longer for the thickness of the finned cover
Old Feb 10, 2023 | 02:37 PM
05stangkc's Avatar
Got it Covered. I was Still Editing While You Posted! Posts a Minute Apart!
KC
ZachBartig
Jul 11, 2018 08:46 PM
mongooztt
Apr 11, 2013 08:16 AM
thahue
Apr 17, 2012 07:00 PM
hahnsolo78
Nov 25, 2011 09:38 AM
300AGT
Dec 14, 2010 10:23 PM
