BMR LCA. What grease should I use?
Old May 7, 2006 | 07:45 PM
WB2005GT's Avatar
I'm looking for suggestions on the best grease to use with BMR LCA's.
Old May 8, 2006 | 06:50 AM
dustindu4's Avatar
9 is not my lucky number.
BMR told me to use Marine grease, it's sold at walmart near the engine oil
Get a gun with the grease to inject it in the zerk fittings
Old May 8, 2006 | 08:14 AM
Cheese302's Avatar
is there a trick to getting the gun onto the zerk fitting? it is just hard to get to.
Old May 12, 2006 | 06:30 PM
traffic142's Avatar
If it is a new gun, the end is tight to push on. I use the red lithium grease. Put on plenty of grease in and around the bushings before you install and it helps. Also buy a flexible end, it gets tight in there.
Old May 13, 2006 | 08:11 PM
WB2005GT's Avatar
Got me some Lucas Oil "Red and Tacky" grease, already had a grease gun.
Thanks.
Old May 13, 2006 | 08:18 PM
Darth Stang's Avatar
White Lithium Marine Grease is the key! Can be purchased at pep boys, autozone, wal-mart, ect. And for everyone whining about the zerk fitting...Go buy some right angle ones and replace it...then you don't have to worry about tight spots!!!!!
-Darth
Old May 14, 2006 | 12:08 AM
Mongoose's Avatar
I never had any problem lubing my BMR lowers and I used red grease. You do have to make sure grease comes out of both ends and it will if they are greased before tightning them down. Panhard rod different story because it has problems with bushings being too long and fitting screw on mine was not on center so no way was grease going through the bushing.. I machined some of the material off the inside end of the bushings to make it work. Also need 90 degree fitting on drivers end to aid lubercating the panhard. I am installing relocation brackets this week if I can find a dry day.
Old May 14, 2006 | 12:12 AM
WB2005GT's Avatar
Thanks, the grease I got is marine grease even though it is red.
Old May 14, 2006 | 12:49 AM
CDGun's Avatar
I ordered the grease along with the LCA right from BMR
Old May 20, 2006 | 07:47 AM
WB2005GT's Avatar
How did you guys attach your e-brake cable? Zip ties?
Old May 20, 2006 | 02:20 PM
Clem's Avatar
That's what I did.
Old May 20, 2006 | 04:04 PM
traffic142's Avatar
same here. I ran them outboard side of the arms. one zip tie per cable is a plenty.
Old May 20, 2006 | 04:21 PM
scramblr's Avatar
Where can I get the 90 degree fittings?
Old May 21, 2006 | 09:15 PM
Torch_Vert's Avatar
Any semi-decent auto parts store (autozone, pep boy's, O'Reilly's, etc)
Old May 21, 2006 | 09:39 PM
scramblr's Avatar
O.K., stupid question I didn't ask earlier. The fitting is for the grease gun, right? Is it universal? I have to order through the Internet, so I'm trying to gather the info. Also...Looks like I can grease the parts before installing? I'm doing it this Friday, so no way I'll get a fitting in time. Thx...
Airborne42
Sep 25, 2015 05:14 PM
SMBJoshy
Aug 16, 2015 02:48 PM
ToddMcF2002
'10-14 Exterior Modifications
17
Aug 3, 2015 07:42 PM
