BMR LCA Relocation Brackets
Old 12/2/05 | 10:02 PM
scotts05custom's Avatar
So, I just bought the BMR Lower Control Arms, and was wandering if I really need to LCA Relocation Brackets?
Do they make a big difference? New to this stuff...
It says they are recomended for lowered cars, and mine is going to be lowered with the Eibach Pro-Kit.
Thanks.
Old 12/2/05 | 10:58 PM
Cleveland's Avatar
Well, it will only improve your traction on launch. After dropping my car with the Eibach Sportlines the angle of the lower control arm was directing upwards to the rear, this causes excessive wheelspin. The relocation brackets correct the angle downwards and cause the rear to dig in.
It was worth it to me and will continue to help me plant for better 60 foots with drag radials.
-Dan
Old 12/3/05 | 09:02 AM
dhof303's Avatar
Thanks.
You dont NEED them, we competed all season last summer without them running 1.65 60ft times. But if you plan on doing a lot of drag racing with sticky tires and want better 60ft times and 1/4mile times then I would say they are a worthwhile investment. We purchased the CHE brackets but I think that both BMR and CHE are great companies when it comes to metal fabrication.
Old 12/19/05 | 12:55 PM
NOLAGT's Avatar
Are the BMR weld in or bolt in? It says weld on the site but the pic looks like its bolted in?
Old 12/19/05 | 01:50 PM
dustindu4's Avatar
9 is not my lucky number.
They're bolt in. They claim they were tested all year at the track with 1.5 sec short times with no problems. You could weld them if you want.
Old 12/19/05 | 02:17 PM
NOLAGT's Avatar
So you dont have to weld them in...I dont plan to go to the track all that oftin if at all at first.
Old 12/19/05 | 02:32 PM
MaverickMLFD371's Avatar
I'm with you, i'm an everyday driver and an occassional visit to the track, I just bought my LCA and my UCA, the non-adjustable one's with poly urethane bushings are best for occassionaly visits to the track, per Jason @ BMR, which is what i ordered.
Old 12/20/05 | 02:23 AM
Cleveland's Avatar
Those BMR brackets are weld in only, it is stated cleary on their site.
-Dan
Old 12/20/05 | 08:11 AM
NOLAGT's Avatar
I was just about to post that Dan...I called them and they told me the same thing.
You think the prokits would make the brackets needed? I know the sport lines are a little lower....
Old 12/20/05 | 02:02 PM
Cleveland's Avatar
I couldnt tell ya for sure if its more of a must-have item or what for your ProKit but you will definitely enjoy more bite by installing them. Cant really hurt.
-Dan
Old 12/20/05 | 06:28 PM
Import-Slaya's Avatar
Bolt-in brackets are available from CHE. I have a set sitting on my workbench right now. Pretty stout pieces and the install should be pretty simple.
2/10/17 07:12 PM
Airborne42
9/25/15 05:14 PM
DrVet
9/23/15 01:48 PM
GrabberBlue310
2012-2013 BOSS 302
9/17/15 08:21 AM
Quick Reply: BMR LCA Relocation Brackets
