Blown GT's w/450+ rwhp, how y'all holding up?
Some time ago, the general consensus was reached that the "safe limit" for our cars on stock internals was around 450 rwhp. Those of you guys who have been running more than that for some time, how's it going?
1) How much rwhp?
2) How long have you been running those levels?
3) Daily driver / racer? What's your driving style?
I've been running just under 450 for a while now. I intentionally requested that level to err on the side of caution, but I'm curious to see how the guys beyond that are doing. I'm wondering if I'm being too conservative...
thanks!
1) How much rwhp?
thanks!
Stay where you are. What's the point in another 40-50 rear wheel? You might not find too many blown (as in blown up) stories on this forum, but if you check others, you will find more and more reports of motor failures and other issues.
Any traction issues? No.....then leave it alone.
Roush TVS at ~11 lbs tuned by VMP Tuning, stock motor, stock heads/cams, stock exhaust manifolds etc etc. Only mods that add power are the Roush TVS, O/R X Pipe, and Magnaflow catback. OEM TR3650 with updated syncros from TSB with McLeod RST. OEM rear differential and gears.
525 rwhp 501 rwtq.
Over a year.
Drive it every day, race it, and beat on it constantly.
525 rwhp 501 rwtq.
Over a year.
465 rwhp,445 rwtq. 48k on the car, 10k with a Whipple. 300= passes on the car since new NA, 100 shot, now Whipple. 11.37 @ 122 best ET to date. Car runs great. Stock 3650 with Spec 3+,AL flywheel,stock motor manifolds, 4.10s, supporting suspension. Considering adding LTs for a little more oomph. Forged bottom end planned for install 2 years from now.
HP & TQ shown in sig. About 10k miles in 18 months with the KB. Not a daily driver, but it has been down the drag strip around 2 dozen times. No problems (knock wood!).
1 Post
Not as much time as some of these guys, but.. stock block down to the exhaust manifolds - Whipple HO kit w/ dyno tune - putting out around 470+ whp now @ 10-11psi
I've got about 7 months at that power level and had the Non-IC kit on her @ 397whp sense April 09. So I'm running just over a year and roughly 5k miles (I think) under pressure. She's not my DD anymore, bought a truck 4 months before the Whipple.
525 rwhp 501 rwtq.
Over a year.
525 rwhp 501 rwtq.
Over a year.
Just sitting shy of 450 rwhp and I am still holding fine. I do feel I will need to change the clutch at some point. I am dialed in and I will not be upping the power. I have a blast every time I drive to work. Exp when I am on the pike and some BmW tries ridding my ars and I just "Hit" it on him...lol at them trying to keep up but still getting smaller in the rear-view....
510 RWHP on pump gas, 550 on 109 Race fuel. 12lbs boost. I drive it and drag race it. Currently runs mid 11s. Hooks well too on 15x10 MT DRs. Been running at this level since Oct 2009. 60lb injectors and gt500 pump gives me spare fuel.
Paxton 2200 HO
Paxton 2200 HO
http://www.moddedmustangs.com/forums...ore-build.html
Im @ 475RWHP and 425---something RWTQ (can't remember)@10lbs boost and pump 91 gas at all times.
Just hit 20K and 2years since the blower was installed. Haven't put a lot of passes on the car though. The clutch lasted about 10K miles and in the 10K since I've put maybe 20 passes at most on the clutch (not entirely happy with the purchase). I don't hammer it when it's first started or if it's blazing hot outside. I am however in boost almost daily and do drive aggressively when the conditions permit. It loves the cold air and will touch 11lbs if I keep my foot in it.
I totally credit my tuner for giving me a reliable but just aggressive enough tune. I'd do it all again in a heartbeat
479RWHP, 455 RWTQ for about 13 months now. Running a Saleen blower with 10-11psi boost.
No issues at all. I've put about 4,000 miles on the car with the blower. I had it dyno tuned by Patrick at PSI Motorsports in Houston and I give him the credit for it holding together. Of course I managed not to screw up my own install too.
