Birdshot in the Adj Panhard Bar works!
Old Feb 4, 2008 | 09:50 PM
MrClean's Avatar
So some of you know I'd removed my adjustable panhard bar because, unlike the stocker, it is hollow and made a hollow/lumber sound when going over sharp drops in pavement, so I bought a 25 lb of lead bird shot ($43), took one end off the panhard bar, and filled it with bird shot. It only took about 3 or 4 lbs of shot to fill it. Reinstalled it, and problem solved, so to y'all who also have this issue, here's the solution.
If anyone's in the Houston area, I still have a s#itload of lead shot left over.
Old Feb 4, 2008 | 10:11 PM
Stoenr's Avatar
You need to lose weight, not add it!
Glad it fixed your issue!
Old Feb 5, 2008 | 05:52 AM
you can also zip tie some pipe wrap around it.
Old Feb 5, 2008 | 05:50 PM
Fman67's Avatar
Good idea
I think that was a cool idea...the factory bar does have something similar ,if not the same, in it...Ford put it there for a reason...NVH
Old Feb 5, 2008 | 05:58 PM
jayguy's Avatar
I was thinking some spray-foam inside it might work too. I dunno if I'm going to try it though, I don't notice the noise that much.
Old Feb 5, 2008 | 08:39 PM
Cavero's Avatar
Huh. I noticed the factory bar had something equivalent to sand in it, never figured it out. I can live with NVH though. I like road noise.
papayote
Ecoboost
Feb 21, 2017 11:16 PM
Evolution Performance
Northeast
Aug 5, 2016 12:46 PM
seaclam
Sep 25, 2015 01:29 PM
Glenn
Sep 23, 2015 08:37 AM
