Axle Back install help?
Old 4/21/06 | 01:25 PM
<div class='quotetop'>QUOTE(cmm101 @ April 21, 2006, 10:57 AM) Quoted post</div><div class='quotemain'>
Awesome tips everyone, I should be undertaking the swap in a few hours. Unfortunitaly I thought i had access to ramps, but my friend sold his set. I guess i will just have to make due without them, I am pretty confident. After all is said and done, I will surly report back and let everyone know how it goes.
O ya TacoBill, your write up was the one i was looking for, I actually did do a search before i post this topic but couldn't find it(I thought I was going crazy, could have swore I saw it awhile back) but i guess it did get deleated.
[/b][/quote]
Good luck Chris!
It'll be a bit hard getting to the mid-pipe clamps without the ramps. You can always fine tune the location of the tips later on.
Old 4/21/06 | 11:26 PM
cmm101's Avatar
OK its a success, the borlas are are on and dang they sound sweet. I want to thank everyone that helped me out. It took me about 2 hours, ya it was a little long, but for someone who has never ever worked on a car(not even a oil change) i am pretty susprised at myself. As far as fitment, I got em perfect, knock on wood, no need to adjust midpipe.
Observations:
- They sound like a mustang should, deep and very toned. Reminds me a old mach 1 i saw at a car show.
- There is drone around 1500-2200 rpm, but i actually like.
- I think my computer is relearning with a loss of back pressure, Before install 19mpg, After 12mpg, and it happened almost in a matter of minutes. (or mabey its just the fact i have my foot in in the whole time, cause they sound so sweet) [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img]
- O ya, my shaker 1000 is pretty much useless, I dont think i will listen to radio again in this car, the exhaust is music to my ears
[img]style_emoticons/<#EMO_DIR#>/biggrinjester.gif[/img]
Old 4/21/06 | 11:30 PM
<div class='quotetop'>QUOTE(cmm101 @ April 21, 2006, 9:29 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
That's great, Chris! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Glad the install went well and that your tips don't need further adjustment.
If they ever do fall out of alignment, loosen the over-axle clamp and the mid-pipe clamp, then tighten from rear to front.
Old 4/22/06 | 09:21 AM
Donna's Avatar
Queen Of Nascar
Congrats!! Glad the install went great. I paid $60 for a reputable shop to install mine just because I'm not one to tackle that kind of stuff myself. [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old 8/16/06 | 01:52 PM
nole_trainer's Avatar
Found this old post, this is gonna help me alot!!! Couple of folks recommended a rachet wrench, before I go buy one - what size should I get?? Thanks in advance.......
Old 8/16/06 | 06:08 PM
mrkabc's Avatar
I would make it part of my standard toolkit to have 10mm and 13mm ratchet wrenches.
I believe those are the sizes you need to do your exhaust.
Old 8/17/06 | 07:39 PM
Indystang's Avatar
My Flowmasters went on like a breeze thanks to the tips I read about here in the Forum. I got both sides on whith my car up on my Rhino Ramps in about one hour!
Old 9/2/06 | 08:47 AM
Ok, I finally just got mine installed!! Pretty easy with all the tips given on this site!! Thanks....
A couple of post install questions. Should they vibrate/shimmer a little? And how far out should they stick? (I guess I really can't control that, but they just seem to stick out)
Here's a side view
Old 9/2/06 | 02:51 PM
06GTwJUICE's Avatar
200 dollars to install and axle back?
I would have done it for a six pack and a bag of beef jerky...
Old 9/4/06 | 12:35 AM
MrLatte's Avatar
This may be a dumb question, but I don't have my car yet to check these things out.
Using the ramps, are you raising just the rear of the car? And is there actually clearance to drive up on them? If only the rears, drive on or back on to them?
Where do you buy Rhino Ramps? Thanks!
Old 9/4/06 | 01:38 PM
eci's Avatar
eci
Rhino Ramps scare me. They're cheezeball Pep Boys plastic ramps they claim to only allow a 7.5" tire.
I bought a set of ML66 from here:
http://dambachramps.com/oilchangedisplay.html
Extremely expensive in comparison, but worth it as even if your car is lowered, you can still use them. They are 14" wide as well.
Old 9/7/06 | 05:17 PM
rnail's Avatar
Installed FRPP - clamp tightening question
Installed the FRPP stingers today. Big difference in sound at start up, very deep. Pulse at low idle just right, slightly louder than stock, not obnoxious. At WOT, slightly louder than stock. The big difference is the deep resonation around town. There is some drone in 1300-2000 range with peak about 1700 RPM, but I like it as it sounds classic muscle.
They lined up perfectly, no adjust necessary and look great! I'm having a problem with the clamps, especially on the left. No matter how hard I tighten the clamp, after I drive around a while the muffler side pipe slides back on the intermediate pipe about 3/8 of an inch. What can I do to keep the pipe seated? Has anyone else had this problem?
Old 9/7/06 | 05:24 PM
Mustang Buster's Avatar
Just because something is plastic does not make it bad. I have had my Rhino Ramps for years, and have had everything from Pickups, to Passenger cars, to Corvettes, to Mustangs on them, and they are solid. They are available at Wal-Mart in the automotive section.
Old 9/7/06 | 05:37 PM
neil07gt's Avatar
yes. i installed my 2 days ago with the same left side difficulties. As i tried to apply additional torque to tight the clamp it would tend to pull the two sections apart. I ended up putting a jack under elbow portion of the axle back to keep it from sliding while i continued to tighten that clamp. I was still a bit unsure if i got the clamp tight enough to keep it from working loose. I checked it this morning (which is a day later), and it still seems to be holding firm. Maybe a U-bolt type clamp would be better for this kit.
Andy11859
Which is Better
9/10/15 01:07 PM
glo106
8/11/15 09:29 AM
valanahara
7/22/15 06:13 PM
Kgilly
7/9/15 02:47 PM
