AutoMeter Shift Lights
Old Nov 30, 2007 | 12:40 PM
2006GT's Avatar
Has onyone installed one these? http://www.autometer.com/cat_accesso...l.aspx?vid=202
Just wondering is it installs the same as a raptor shift light or if I need to buy other stuff to make it work...
Old Dec 1, 2007 | 06:55 AM
2006GT's Avatar
Anyone? Hello?
Old Dec 5, 2007 | 03:35 PM
07Foose's Avatar
I have the Raptor and now that I see that Autometer I wish I had gotten the Autometer one for the RPM display and multicolor selection...
Old Dec 6, 2007 | 09:42 PM
SurfNut's Avatar
Autometer level 2 gauge type
I've got this one.
I use a FRPP tach adapter to get a tach signal.
Works perfect.
Old Dec 6, 2007 | 10:07 PM
dly's Avatar
dly
No need for the tach adpater. just hook up the autometer to any coil, just don't use the red wire and set the autometer to .5 to get the correct RPM's. Works great.
Old Dec 7, 2007 | 09:25 PM
91svtcoupe's Avatar
bought my today
I bought mine today...so I will let you know...good deal in my opinion....
http://cgi.ebay.com/ebaymotors/ws/eB...181268376&rd=1
Old Dec 25, 2007 | 10:43 AM
2006GT's Avatar
Hey did you et yours installed?? Wonder how ait went and if you used the coil wire method. Thanks!
Old Dec 25, 2007 | 11:49 AM
05Blackbeauty's Avatar
I wonder what the diameter of this thing is? I might want to replace the raptor with this if it would fit in the cig lighter w/the PMP holder.
Old Dec 25, 2007 | 12:52 PM
Pwny's Avatar
Is there anything wrong with the Raptor light or does it simply come down to a matter of cost?
Old Dec 25, 2007 | 01:35 PM
91svtcoupe's Avatar
here are my pictues..
I used the last coil wire on the drives side..white with red stripe....same one taco used with raptor light. For power used an add a circuit in the fuse box and just grounded to a bolt at the steering shaft. I like it...at first wasn't too sure about it but now It is growing on me. Kinda of neat will be more useful when I install the supercharger I am sure. Thanks
That is not a 7k light coming on...I just turned it off....so you could see the light. Thanks
Old Dec 25, 2007 | 01:51 PM
Nothing wrong with the raptor at all. I would just like the capability to set diff lights for diff shift points/gears.
Old Dec 25, 2007 | 02:10 PM
2006GT's Avatar
Thanks man! Hooking her up now.
I hope that's not the actual shift light at 7k... Because you're about to hit an Expedition...
Old Dec 25, 2007 | 02:12 PM
2006GT's Avatar
Word... I got the Lvl 2 which also has the launch setting. The rator can only be set to one rpm setting. The Autometer has 5 shift settings and the launch.
Old Dec 25, 2007 | 02:33 PM
2006GT's Avatar
What pulse setting did you use??
Old Dec 25, 2007 | 02:51 PM
2006GT's Avatar
Nevermind... Looks like it's .5..
One more question...
Where did you route the blue wire ? I attached it to the Clutch switch. It's does not seem to be picking up a signal... (Launch setting).
Old Dec 25, 2007 | 04:08 PM
Pwny's Avatar
Looks great!
Old Dec 25, 2007 | 06:12 PM
91svtcoupe's Avatar
Mine is
Mine is just a level one....no shift settings or such....just 3 wires no blue one....just green, red black..sorry. Thanks again Rob....
yea went with .5
what is the best shift point?
Old Dec 25, 2007 | 07:38 PM
2006GT's Avatar
Since my rev limiter is set to 6800rpm, I set mine at 6400rpm. i'll play with it to see what works best...
Old Jan 7, 2008 | 09:23 AM
rdw401's Avatar
RPM Shift Point
I thought the shift point on our 4.6 stock engines was about 6,000? Are they really up at 6,800?
I guess I need to look at some stock dyno runs.
Old Jan 13, 2008 | 07:26 PM
91svtcoupe's Avatar
moved shift light
moved shift light....you like?
