AutoMeter Shift Lights
Has onyone installed one these? http://www.autometer.com/cat_accesso...l.aspx?vid=202
Just wondering is it installs the same as a raptor shift light or if I need to buy other stuff to make it work...
Anyone? Hello?
bought my today
I bought mine today...so I will let you know...good deal in my opinion....
http://cgi.ebay.com/ebaymotors/ws/eB...181268376&rd=1
here are my pictues..
I used the last coil wire on the drives side..white with red stripe....same one taco used with raptor light. For power used an add a circuit in the fuse box and just grounded to a bolt at the steering shaft. I like it...at first wasn't too sure about it but now It is growing on me. Kinda of neat will be more useful when I install the supercharger I am sure. Thanks
That is not a 7k light coming on...I just turned it off....so you could see the light. Thanks
I hope that's not the actual shift light at 7k... Because you're about to hit an Expedition...
Word... I got the Lvl 2 which also has the launch setting. The rator can only be set to one rpm setting. The Autometer has 5 shift settings and the launch.
Nevermind... Looks like it's .5..
One more question...
Where did you route the blue wire ? I attached it to the Clutch switch. It's does not seem to be picking up a signal... (Launch setting).
Since my rev limiter is set to 6800rpm, I set mine at 6400rpm. i'll play with it to see what works best...
