Anyone installed o2 sensor risers?
Old Jan 16, 2012 | 02:32 PM
Stormbringer's Avatar
All,
Im running a Bassani X-pipe with high flow cats. When I load up a tune that turns o2 sensors on after a while I get a code set for Catalyst below threshold...
Has anyone tried using o2 sensor risers to move the sensor out of the direct flow to combat this?
Related:
http://www.brenspeed.com/730-2442.html
Old Jan 16, 2012 | 02:39 PM
AlsCobra's Avatar
A Man Just Needs Some....
It's easy to install and it's cheap. I never seen these before but it's worth a try for sure.
Old Jan 29, 2012 | 04:07 PM
HG6283's Avatar
Originally Posted by Stormbringer
All,
Related:
Yes. Installed 1 set, and still got codes. Then I installed 2 sets. No more codes.
Old Jan 30, 2012 | 04:41 PM
Ive had mine in for just over 400 miles and still no codes. The important thing is I was able to finally get my car inspected.
Old Jan 31, 2012 | 05:30 PM
paps's Avatar
I installed the non fouler thing from brenspeed, and it didn t work... Still cel fault. I disabled o2 sensor with my tuner
Old Jan 31, 2012 | 05:44 PM
TexasStangGT's Avatar
I had the same issue with hi-flow cats and I used the "spark plug non-fouler trick" and it worked for me after using two sets for each rear O2 sensor https://themustangsource.com/f637/mi...09-gts-494749/
Old Feb 3, 2012 | 10:37 AM
That wouldn't work for me here in Texas. I installed the Brenspeed tune in my car to turn the light off and when inspected it failed because O2, O2 heater, and Catalyst were all not ready. I asked Brent if he could set it so only Catalyst would be not ready and he said he couldn't. Appears its an all or nothing type thing.
He suggested we use the tune with O2 on and the non foulers which so far is still working for me.
Oh, by the way... The one's that Brenspeed is selling do not require any drilling to be done on your part for the sensor to fit.
Sep 10, 2015 12:44 PM
haitham
Sep 8, 2015 12:52 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
